I have an example repository with two flakes:
a/flake.nixexporting some package:{ description = "Flake A"; inputs = { nixpkgs.url = "github:NixOS/nixpkgs"; flake-utils.url = "github:numtide/flake-utils"; }; outputs = { self, nixpkgs, flake-utils }: flake-utils.lib.eachDefaultSystem (system: let pkgs = import nixpkgs { inherit system; }; in { packages.default = pkgs.hello; } ); } -
b/flake.nixwhich getsaas input:{ description = "Flake B"; inputs = { a.url = "path:./../a"; nixpkgs.follows = "a/nixpkgs"; flake-utils.follows = "a/flake-utils"; }; outputs = { self, a, nixpkgs, flake-utils }: flake-utils.lib.eachDefaultSystem (system: { packages.default = a.packages."${system}".default; }); }
This works well on darwin but on linux you run into the fact that path inputs must be absolute:
$ cd b
$ nix build
error: cannot fetch input
'path:./../a?lastModified=1&narHash=sha256-xlRoGtT72GTwflhQ8QNxtx3Ws51mf0b90aUfh2uW5Bg%3D'
because it uses a relative path
One attempt to fix this is to remove the path: type in front of the input Here’s that “fix” inlined:
diff --git a/b/flake.nix b/b/flake.nix
index 6408279..cfc118f 100644
--- a/b/flake.nix
+++ b/b/flake.nix
@@ -2,7 +2,7 @@
- a.url = "path:./../a";
+ a.url = "./../a";
However, after running cd b; nix flake update this changes b/flake.lock to:
diff --git a/b/flake.lock b/b/flake.lock
index 1464e8e..47b22e6 100644
--- a/b/flake.lock
+++ b/b/flake.lock
@@ -8,11 +8,11 @@
"locked": {
"lastModified": 1,
"narHash": "sha256-xlRoGtT72GTwflhQ8QNxtx3Ws51mf0b90aUfh2uW5Bg=",
- "path": "./../a",
+ "path": "/nix/store/y15jkqn1bgs4cskgczz0b11szz673hhw-source/a",
"type": "path"
"original": {
- "path": "./../a",
"type": "path"
The problem with this is that the whole repository is copied into the /nix/store before b/flake.lock gets updated with the /nix/store path it will get copied to. This means that running nix flake update again will now result in a different store path since b/flake.lock got changed. This will happen ad infinitum.
At this point I’m stuck. What’s the right way of referencing flakes from the same repository?
