How to set startup script in Fish shell using home-manager?
I am running Debian with home-manager.
I want to run a script when the Fish shell starts. It is usually placed at ~/.config/fish/conf.d/ but how do I do it with home-manager?
What I tried:
options.programs.fish.interactiveShellInit = mkOption {
        type = types.lines;
        default = "fnm env --use-on-cd | source";
        description = ''
          Shell script code called during interactive fish shell
          initialisation.
But it gives the following error:
❯ home-manager switch
error: undefined variable 'mkOption'
       at /home/user/.config/nixpkgs/home.nix:71:48:
           70|
           71|   options.programs.fish.interactiveShellInit = mkOption {
           72|     type = types.lines;
Basically I am tring to setup fnm for fish shell.
That’s how you would create a completely new option. You’d also have to make mkOption available from nixpkgs’ lib to do this.
But this option already exists: Appendix A. Configuration Options
Just set it:
programs.fish.interactiveShellIinit = ''
