Hi All.
Im trying to work out how to setup NUR so I can install packages from it. Specifically with home-manager setup via flakes.
I have added it as an input to my flake.nix (flake.nix · d95b450dbd131da1537befb53516aee602ddec0f · Haseeb Majid / dotfiles · GitLab)
nur.url = "github:nix-community/NUR";
Where my home manager setup looks like (flake.nix · d95b450dbd131da1537befb53516aee602ddec0f · Haseeb Majid / dotfiles · GitLab):
mkHome = modules: pkgs: home-manager.lib.homeManagerConfiguration {
inherit modules pkgs;
extraSpecialArgs = { inherit inputs outputs; };
homeConfigurations = {
# Laptops
"haseeb@framework" = mkHome [ ./home/haseeb/framework.nix ] nixpkgs.legacyPackages."x86_64-linux";
I tried to set nur overlays and then finally I tried to install some rofi packages (home/haseeb/features/desktops/hyprland/rofi.nix · d95b450dbd131da1537befb53516aee602ddec0f · Haseeb Majid / dotfiles · GitLab):
nixpkgs.overlays = [
inputs.nur.overlay
home.packages = with pkgs; [
rofi-systemd
rofi-power-menu
nur.repos.peel.rofi-wifi-menu
nur.repos.peel.rofi-emoji
But when I run home-manager switch --flake ~/dotfiles#haseeb@framework
I’ve tried numerous different iterations and get the same error:
error:
at //builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation 'home-manager-generation'
whose name attribute is located at /nix/store/85jb4qwmnjgc09imq5ia8qavklwc3mgb-source/pkgs/stdenv/generic/make-derivation.nix:303:7
… while evaluating attribute 'buildCommand' of derivation 'home-manager-generation'
at /nix/store/85jb4qwmnjgc09imq5ia8qavklwc3mgb-source/pkgs/build-support/trivial-builders/default.nix:87:14:
86| enableParallelBuilding = true;
87| inherit buildCommand name;
88| passAsFile = [ "buildCommand" ]
error: attribute 'lib' missing
at /nix/store/ih5mbzgcmymnz9mfw77qp73w2qw9z69d-source/pkgs/misc/rofi-wifi-menu/default.nix:42:15:
41|
42| meta = with stdenv.lib; {
43| description = "A rofi wifi control panel";
I’m pretty new to nix and dont understand where I’m going wrong ? It works if I use it with nixos configuration following this guide; GitHub - nix-community/NUR: Nix User Repository: User contributed nix packages [maintainer=@Mic92].
However I think this belongs in the home manager config. Thanks.
