I’m trying to install DocArray and Jina Hubble SDK using Nix, but I’m encountering a circular dependency issue. Specifically, I need to install DocArray to proceed with the installation of Jina Hubble SDK, but Jina Hubble SDK is a prerequisite for installing DocArray.
flake.nix
{ description = "Python environment with ollama";
inputs.nixpkgs.url = "github:NixOS/nixpkgs/nixos-unstable"; inputs.flake-utils.url = "github:numtide/flake-utils";
outputs = { self, nixpkgs, flake-utils, ... }:
flake-utils.lib.eachDefaultSystem (system: let
#Define Python package jina-hubble-sdk
jina-hubble-sdk = with pkgs.python3Packages;
buildPythonPackage rec {
pname = "jina-hubble-sdk";
version = "0.39.0";
src = pkgs.fetchPypi {
inherit pname version;
sha256 = "9021417794a6d3cf3fad8a880cf668a3a986b9d53d5be5fa391aae1767a5b9b0";
preConfigure = ''
export HOME=$(mktemp -d)
nativeBuildInputs = [
poetry-core
propagatedBuildInputs = [
opentelemetry-instrumentation-grpc
uvloop
aiofiles
websockets
pep517
pip
requests
aiohttp
rich
importlib-metadata
filelock
pathspec
docker
pyyaml
python-jose
# # Define Python package jcloud
jcloud = with pkgs.python3Packages;
pname = "jcloud";
version = "0.3";
sha256 = "dc062c0454041562476032768fc48f426cc40b8e2323d9626377ff44b0d6f3d9";
preConfigure = ''
poetry-core
pip
rich
aiohttp
jina-hubble-sdk
packaging
pyyaml
python-dotenv
python-dateutil
#python-dateutil
#python-dotenv
#pyyaml
# Add any dependencies jcloud might have here
# Define Python package jina
jina = with pkgs.python3Packages;
pname = "jina";
version = "3.24.0";
sha256 = "91f7a6141f46884b87d011e64cbf053391d418289391c3c633b10f0c7942553b";
poetry-core
pip
jcloud
# Add any dependencies jina might have here
# Define Python package docarray
docarray = with pkgs.python3Packages;
pname = "docarray";
version = "0.40.0";
format = "pyproject";
sha256 = "c3f3b88b7b6128c10308dddbd21650c9845e270da850cf6718cb1d3d867d5986";
poetry-core
numpy
orjson
pydantic
rich
types-requests
typing-inspect
# Define Python package vectordb
vectordb = with pkgs.python3Packages;
pname = "vectordb";
version = "0.0.21";
sha256 = "3f4857ed3f26dc2384415f28851526037058008156719ca0cfc208a9a02d88e8";
poetry-core
pip
setuptools
docarray
jina
# Define Python environment with necessary packages
pythonEnv = pkgs:
pkgs.python3.withPackages (ps:
with ps; [
langchain-community
langchainplus-sdk
langchain
tiktoken
docarray
vectordb
jina # Include jina in the environment
jcloud # Include jcloud in the environment
buildInputs = with pkgs; [
curl
ollama
(pythonEnv pkgs)
If you run the flake after commenting every python package above docarray, you get this error when running the flake:
error:
… while calling the ‘derivationStrict’ builtin
at /builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation ‘nix-shell’
whose name attribute is located at /nix/store/zaza7mgggz4m5h6z18kajabf4wciaj47-source/pkgs/stdenv/generic/make-derivation.nix:331:7… while evaluating attribute ‘buildInputs’ of derivation ‘nix-shell’
at /nix/store/zaza7mgggz4m5h6z18kajabf4wciaj47-source/pkgs/stdenv/generic/make-derivation.nix:378:7: 377| depsHostHost = elemAt (elemAt dependencies 1) 0; 378| buildInputs = elemAt (elemAt dependencies 1) 1; | ^ 379| depsTargetTarget = elemAt (elemAt dependencies 2) 0;
(stack trace truncated; use ‘–show-trace’ to show the full trace)
error: undefined variable ‘jina’
at /nix/store/9z9khfrsm3dx1jh55cw09zi36l6dg1q2-source/flake.nix:162:13:
161| vectordb 162| jina # Include jina in the environment | ^ 163| jcloud # Include jcloud in the environment
It means you have to install jcloud. uncomment jcloud. the error message say you have to install another package. Therefore you uncomment more until you uncomment the jina-hubble-sdk package. And you get this error
error: builder for ‘/nix/store/c4xggnbjhl6wj6w71c6nszzxx39iv93a-python3.11-jina-3.24.0.drv’ failed with exit code 1; last 10 log lines: > ir_d = dist.fetch_build_eggs(dist.install_requires) > WARNING: The directory ‘/homeless-shelter/.cache/pip’ or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo’s -H flag. > WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff55a3cd0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’)‘: /simple/docarray/ > WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff55b07d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’)‘: /simple/docarray/ > WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff55b1310>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’)‘: /simple/docarray/ > WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff55b1e10>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’)‘: /simple/docarray/ > WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘NewConnectionError(’<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7ffff55b2990>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’)‘: /simple/docarray/ > ERROR: Could not find a version that satisfies the requirement docarray>=0.16.4 (from versions: none) > ERROR: No matching distribution found for docarray>=0.16.4 > error: Command ‘[’/nix/store/3v2ch16fkl50i85n05h5ckss8pxx6836-python3-3.11.8/bin/python3.11’, ‘-m’, ‘pip’, ‘–disable-pip-version-check’, ‘wheel’, ‘–no-deps’, ‘-w’, ‘/build/tmp0nl2c1kv’, ‘–quiet’, ‘docarray>=0.16.4’]’ returned non-zero exit status 1. For full logs, run ‘nix log /nix/store/c4xggnbjhl6wj6w71c6nszzxx39iv93a-python3.11-jina-3.24.0.drv’. error: 1 dependencies of derivation ‘/nix/store/gw13rrga3q9mfsyly7lksmqpz85b81gd-python3-3.11.8-env.drv’ failed to build error: 1 dependencies of derivation ‘/nix/store/81jdcd1la69iry4f83cgwhim27gvnvsb-nix-shell-env.drv’ failed to build
It means that you have to install docarray. How can solve this circular dependency problem
