How to solve libstdc++ not found in shell.nix
Hello,
I am trying to run nix-shell to use poetry (and hopefully poetry2nix). I am stuck with an error from an executable from a python package that claims libstdc++ is missing.
I’ve found something that looks like a solution on Packaging/Quirks and Caveats - NixOS Wiki (linked from What package provides libstdc++.so.6?)
but it is for packaging and not nix-shell.
With nix-shell I get the error
error: undefined variable 'stdenv'
       at /home/espen/code/python-fmri-env/shell.nix:11:23:
           10|     # fixes libstdc++ issues
           11|     LD_LIBRARY_PATH=${stdenv.cc.cc.lib}/lib/
           12|     '';
So how to I refer to this variable in shell.nix? I’ve tried to add stdenv like { stdenv, pkgs ? import … } but no luck. I need it to work both on Nix and on NixOS.
shell.nix:
pkgs.mkShell {
  buildInputs = [
    pkgs.python310
    pkgs.poetry
  shellHook = ''
    # fixes libstdc++ issues and libgl.so issues
EDIT: clarity and mistakes
stdenv is in pkgs, so just use pkgs.stdenv.cc.cc.lib.
Thank you!
shell.nix now evaluates, but unfortunately I still get the same error. Seems like the solution I linked to wasn’t enough.
The error message I get is:
(python-fmri-env-py3.10) espen@mainframe-ubuntu:~/code/python-fmri-env$ clinica
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/bin/clinica", line 5, in <module>
    from clinica.cmdline import main
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/clinica/cmdline.py", line 13, in <module>
    from clinica.iotools.converters.cli import cli as convert_cli
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/clinica/iotools/converters/cli.py", line 5, in <module>
    from .habs_to_bids import habs_to_bids_cli
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/clinica/iotools/converters/habs_to_bids/habs_to_bids_cli.py", line 5, in <module>
    import clinica.iotools.bids_utils as bids
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/clinica/iotools/bids_utils.py", line 7, in <module>
    from pandas import DataFrame
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/__init__.py", line 48, in <module>
    from pandas.core.api import (
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/api.py", line 47, in <module>
    from pandas.core.groupby import (
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/groupby/__init__.py", line 1, in <module>
    from pandas.core.groupby.generic import (
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/groupby/generic.py", line 76, in <module>
    from pandas.core.frame import DataFrame
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/frame.py", line 172, in <module>
    from pandas.core.generic import NDFrame
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/generic.py", line 169, in <module>
    from pandas.core.window import (
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/window/__init__.py", line 1, in <module>
    from pandas.core.window.ewm import (
  File "/home/espen/.cache/pypoetry/virtualenvs/python-fmri-env-5taD3dGB-py3.10/lib/python3.10/site-packages/pandas/core/window/ewm.py", line 15, in <module>
    import pandas._libs.window.aggregations as window_aggregations
ImportError: libstdc++.so.6: cannot open shared object file: No such file or directory
I get the same error both with Ubuntu/Nix and NixOS. Any ideas how to fix this?
it might be because that LD_LIBRARY_PATH is not exported
Amazing, that works! Good catch!
Just a word of warning.
There are circumstances under which the shellhooks are not effective.
You should prefer to set envvars via attributes whenever possible, as that is more reliavble.
Thanks for the warning. How would I define the library path through an attribute?
If you could point me in the direction where I should look in the documentation that would also be great.
mkShell {
  LD_LIBRARY_PATH = "${stdenv.cc.cc.lib}/lib";
Thank you, this solved a longstanding problem for me. Just for completness and for everybody who comes after me (especially myself a few weeks in the future), here is a complete shell.nix that works for me (you probably don’t need the unstable part):
  unstable = import (fetchTarball "https://releases.nixos.org/nixos/unstable/nixos-22.11pre421761.\
448a599c499/nixexprs.tar.xz") { };
{ nixpkgs ? import <nixpkgs> {} }:
nixpkgs.mkShell {
  nativeBuildInputs = with nixpkgs; [
    unstable.python310Packages.poetry
    unstable.python310
  LD_LIBRARY_PATH = "${nixpkgs.stdenv.cc.cc.lib}/lib";
It took 3 months, but it was worth it.
This has worked to me:
  environment = {
    sessionVariables = {
      LD_LIBRARY_PATH = "${pkgs.stdenv.cc.cc.lib}/lib";
No, please give What package provides libstdc++.so.6? - #5 by NobbZ a read.
What’s the difference between this and your own suggestion?
That you put it into the global environment, rather than a dev shell.
For other readers, especially if you have multiple libraries you might consider lib.makeLibraryPath, which will combine its inputs properly and add the /lib for you. For example:
pkgs.mkShell {
    LD_LIBRARY_PATH = lib.makeLibraryPath [ pkgs.stdenv.cc.cc ];
is there a way to check the versions going into pkgs.stdenv.cc.cc? like if I need libstdc++ to be >= 7.1`
Thanks, this works for me.
Might be a bit late to the party here but if anyone is struggling a bit to make this work still, I was able to resolve it using a shell.nix file in the repository. I am using uv to manage the project.
My configuration.nix looks like this:
    unixODBC
    unixODBCDrivers.msodbcsql18
    sqlcmd
  environment.unixODBCDrivers = with pkgs.unixODBCDrivers; [ msodbcsql18 ];
  programs.nix-ld.enable = true;
I then have the following shell.nix in the top folder of my python project:
with import <nixpkgs> { };
pkgs.mkShell {
  name = "loc-engine";
  # Here is where you will add all the libraries required by your native modules
  # You can use the following one-liner to find out which ones you need.
  # Just make sure you have `gcc` installed.
  # `find .venv/ -type f -name "*.so" | xargs ldd | grep "not found" | sort | uniq`
  NIX_LD_LIBRARY_PATH = lib.makeLibraryPath [
    stdenv.cc.cc # libstdc++
    stdenv.cc.cc.lib
    zlib # libz (for numpy)
    #libstdc++.so.6
    #libz.so.1
  NIX_LD = lib.fileContents "${stdenv.cc}/nix-support/dynamic-linker";
  packages = with pkgs; [
    uv
(I got this from crescentrose, which was the only way I could get things working)
Once in the root folder (and after a nix-os rebuild), run nix-shell (I use nix-shell –run zsh to preserve my zsh terminal) and you should then be able to do your usual uv sync functions from here).
A useful tip in this case where your collaborators may not be using nix is to put shell.nix in .git/info/exclude, which is like .gitignore but will not appear to the other collaborators in the repo
