I am looking at
and my package declaration
pkgs.mkchromecast
I need to enable enableSonos = true
but how do I pass this to the package module?
I am looking at
pkgs.mkchromecast
Well, to answer the question, instead of pkgs.mkchromecast
you would use (pkgs.mkchromecast.override { enableSonos = true; })
(note the parentheses).
But it’s enabled already? The default is true
Ah, I guessed so but, what I dont understand is how the other parameters are in NixOS/nixpkgs/blob/da4024d0ead5d7820f6bd15147d3fe2a0c0cec73/pkgs/applications/networking/mkchromecast/default.nix#L15
are determined. I think I got some fundamental problems in understanding such a Nix expression and then using override
Files like that are imported something like callPackage ./pkgs/applications/networking/mkchromecast {}
. The callPackage
function takes care of pulling values for all the arguments from pkgs
, so e.g. pkgs.ffmpeg
will be passed as the ffmpeg
argument automatically. The {}
argument can contain overrides, but you can also use the resulting .override
function to provide overrides. Any argument that callPackage
can’t pull from pkgs
(such as enableSonos
) will result in an error unless that argument has a default (which is what the ? true
syntax does).
Strange, so hypothetically whenever enableSonos
becomes a new package
in nixpkgs, than this file will somehow crash
because its no more a simple boolean? What would happen then? Isnt that a bit implicit behavior?
Yea. It’s a good thing enableSonos
is a very unlikely name for a package
