How to use a system-imported executable in a script?
I’m currently trying to use nvidia-smi in a root script. The issue is that its not in nixpkgs, its from one of the virtualization options ( probably graphics.nvidia.open = true ). How would I go about importing it in a script, because right now its just crashing with “127 not found”
"passthrough.sh" = pkgs.writeShellScript "passthrough.sh" ''
    ${pkgs.nvidia-smi}/bin/nvidia-smi
    exit $("nvidia-smi")
You should be able to get it from config.hardware.nvidia.package, I think.
Good thought, but it would not appear so. Most of the other stuff is there (drivers)
Ah, I was close. Try config.hardware.nvidia.package.settings. Seems it’s included as a passthru. EDIT: nvm, that’s nvidia-settings, not nvidia-smi.
On my system, nvidia-smi is there if I do a nix build of my config.hardware.nvidia.package.bin.
looks like it appears in the store ending with nvidia-x11. just have no idea how to get to it
I do (lib.getBin config.hardware.nvidia.package) in my config get the package containing nvidia-smi. Adding “/bin/nvidia-smi” should work.
A simpler equivalent would be
lib.getExe' config.hardware.nvidia.package "nvidia-smi"
