How to use `buildNpmPackage` for a pnpm project?
Hi!
I’m trying to write a flake to package a project of mine that uses pnpm, this is the project’s structure:
.dir-locals.el
.dockerignore
.envrc
.github/workflows/test.yaml
.gitignore
.gitmodules
Dockerfile
Makefile
README.md
flake.lock
flake.nix
index.ts
package.json
pnpm-lock.yaml
protobuf-files
src/configuration.ts
src/protobuf/moonshine.ts
src/protobuf/swap.ts
src/server.ts
src/server_moonshine.ts
tsconfig.json
And this is the flake.nix I was been able to put together:
# This flake was initially generated by fh, the CLI for FlakeHub (version 0.1.9)
  # Flake inputs
    pre-commit-hooks.url = "github:cachix/pre-commit-hooks.nix";
    flake-schemas.url = "https://flakehub.com/f/DeterminateSystems/flake-schemas/*.tar.gz";
    nixpkgs.url = "https://flakehub.com/f/NixOS/nixpkgs/0.1.*.tar.gz";
  # Flake outputs that other flakes can use
  outputs =
      self,
      flake-schemas,
      nixpkgs,
      pre-commit-hooks,
      # Helpers for producing system-specific outputs
      supportedSystems = [
        "x86_64-linux"
        "aarch64-darwin"
        "x86_64-darwin"
        "aarch64-linux"
      forEachSupportedSystem =
        f:
        nixpkgs.lib.genAttrs supportedSystems (
          system:
          f {
            inherit system;
      # Schemas tell Nix about the structure of your flake's outputs
      schemas = flake-schemas.schemas;
      checks = forEachSupportedSystem (
          system,
          pkgs,
          pre-commit-check = pre-commit-hooks.lib.${system}.run {
            src = ./.;
            hooks = {
              alejandra.enable = true;
              deadnix.enable = true;
              biome = {
                excludes = [ "src/protobuf" ];
              yamllint = {
                entry = "${pkgs.python311Packages.yamllint}/bin/yamllint --no-warnings";
                excludes = [ "pnpm-lock\\.yaml" ];
      packages = forEachSupportedSystem (
        { system, pkgs }:
          default = pkgs.buildNpmPackage {
            pname = "calisto";
            version = "0.1.0";
            src = ./.;
            npmDepsHash = "sha256-hFtcQ1jSlPKqU2OlqjhknkzUkZbnma5FbrBNUc8gDLw=";
            npmInstallFlags = [ "--production" ];
            npmBuildScript = "build";
      # Development environments
      devShells = forEachSupportedSystem (
          pkgs,
          system,
          default = pkgs.mkShell {
            buildInputs = self.checks.${system}.pre-commit-check.enabledPackages;
            # Pinned packages available in the environment
            packages = with pkgs; [
              curl
              jq
              just
              nodejs-slim
              nodePackages.prettier
              nodePackages.npm
              nodePackages.pnpm
              typescript
              nodePackages.typescript-language-server
              protobuf
              grpcui # cliente gRPC
              self.packages.${system}.default
However I’m met with the following error:
➜  nix log /nix/store/h3gnsxs0wxgcla3pzgmd3xsq9bl6k5ks-calisto-0.1.0-npm-deps.drv
warning: The interpretation of store paths arguments ending in `.drv` recently changed. If this command is now failing try again with '/nix/store/h3gnsxs0wxgcla3pzgmd3xsq9bl6k5ks-calisto-0.1.0-npm-deps.drv^*'
@nix { "action": "setPhase", "phase": "unpackPhase" }
Running phase: unpackPhase
unpacking source archive /nix/store/gm52ma7c2sqg3qbfzxpnk9xjvricfckc-c0k6l9wki90c47xlf0>
source root is c0k6l9wki90c47xlf0j273qbsih3ifgg-source
@nix { "action": "setPhase", "phase": "patchPhase" }
Running phase: patchPhase
@nix { "action": "setPhase", "phase": "updateAutotoolsGnuConfigScriptsPhase" }
@nix { "action": "setPhase", "phase": "configurePhase" }
Running phase: configurePhase
@nix { "action": "setPhase", "phase": "buildPhase" }
Running phase: buildPhase
ERROR: The package-lock.json file does not exist!
package-lock.json is required to make sure that npmDepsHash doesn't change
when packages are updated on npm.
Hint: You can copy a vendored package-lock.json file via postPatch.
The documentation does not touch on the topic of NodeJS with pnpm so it is hard to navigate the problem for a solution.
This is the section of the nixpkgs documentation about packaging pnpm projects: Nixpkgs Reference Manual
I don’t understand it in relationship with the flake as I’m not using stdenv.mkDerivation anywhere
EDIT:
Okay, nevermind, I made the following changes:
        { system, pkgs }:
          default = pkgs.stdenv.mkDerivation {
            pname = "calisto";
            version = "0.1.0";
            src = ./.;
            nativeBuildInputs = [
              pkgs.nodejs
              pkgs.pnpm.configHook
              pkgs.typescript
            installPhase = ''
              mkdir -p $out/bin
              cp -r dist $out/
              echo '#!${pkgs.bash}/bin/bash' > $out/bin/calisto
              echo '${pkgs.nodejs}/bin/node $out/dist/index.js "$@"' >> $out/bin/calisto
              chmod +x $out/bin/calisto
            pnpmDeps = pkgs.pnpm.fetchDeps {
              inherit (self.packages.${system}.default) pname version src;
              hash = "sha256-7NgYqOUOMa1xZlTJf1QTLmGl1TI55o58RxpcF+EBOa0=";
And now it looks like it is working
any idea how I can call my script on dist/index.js? I write a shell script with:
but calling the command fails:
➜  calisto
node:internal/modules/cjs/loader:1146
  throw err;
Error: Cannot find module '/home/jorge/code/crypto/calisto/outputs/out/dist/index.js'
    at Module._resolveFilename (node:internal/modules/cjs/loader:1143:15)
    at Module._load (node:internal/modules/cjs/loader:984:27)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:135:12)
    at node:internal/main/run_main_module:28:49 {
  code: 'MODULE_NOT_FOUND',
  requireStack: []
Node.js v20.12.2
I don’t know how to solve your issue completely but $out is not what you should use in the second line when writing to $out/bin/calisto.
It should be ${placeholder "out"}/dist/index.js which will be replaced at the end by the real nix store path of the final derivation, instead of local $out variable which is different and will only exist during the time of building (which nix does in a sandbox).
Also checkout pkgs.runtimeShell and patchShebangs (patchShebanges only works with files which have executable permission) you may find them useful.
thank you! _______________________________
yo I’m having a similar issue. I’m trying to package a tauri app that uses pnpm but the lock file is a package-lock.json, so when I try to use fetchPnpmDeps it doesn’t work cuz it can’t find pnpm-lock.yaml:
unpacking source archive /nix/store/6aff8nqvva38ybrsgy1i2cnrh30xmn6c-source
source root is source
Running phase: installPhase
@nix { "action": "setPhase", "phase": "installPhase" }
usage: yq [-h] [--yaml-output] [--yaml-roundtrip]
          [--yaml-output-grammar-version {1.1,1.2}] [--width WIDTH]
          [--indentless-lists] [--explicit-start] [--explicit-end]
          [--in-place] [--version]
          [jq_filter] [files ...]
yq: error: argument files: can't open 'pnpm-lock.yaml': [Errno 2] No such file or directory: 'pnpm-lock.yaml'
Surprisingly, I can’t find anything abt it in the nixpkgs manual.
Here’s the package:
with import <nixpkgs> { };
rustPlatform.buildRustPackage (finalAttrs: {
  pname = "twintaillauncher";
  version = "2.0.0";
  src = fetchFromGitHub {
    owner = "TwintailTeam";
    repo = "TwintailLauncher";
    rev = "ttl-v${finalAttrs.version}";
    hash = "sha256-DTZpfiSD2X6ZgeFMxJXmV+gWm2Okj6DFmLOF7s5+zL0=";
  cargoHash = "sha256-AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=";
  pnpmDeps = fetchPnpmDeps {
    inherit (finalAttrs) pname version src;
    fetcherVersion = 3;
    hash = "sha256-AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA";
    # Pull in our main hook
    cargo-tauri.hook
    # Setup pnpm
    nodejs
    pnpm
    pnpmConfigHook
    # Make sure we can find our libraries
    pkg-config
  ++ lib.optionals stdenv.hostPlatform.isLinux [ wrapGAppsHook4 ];
  buildInputs = lib.optionals stdenv.hostPlatform.isLinux [
    glib-networking # Most Tauri apps need networking
    openssl
    webkitgtk_4_1
  # Set our Tauri source directory
  cargoRoot = "src-tauri";
  # And make sure we build there too
  buildAndTestSubdir = finalAttrs.cargoRoot;
The npm program can’t find the npm deps you fetched, you might want to copy node_modules to a dir under $out like $out/lib then add makeWrapper as input then add this:
postFixup = ''
  wrapProgram $out/bin/calisto \
    --set NODE_PATH $out/lib/node_modules/
