I’m trying to make a Nix flake that has a configurable default module. I frequently have to run nix flake update
from my system’s flake and then run home-manager switch --flake .
. This takes up a lot of requests in several places and I soon become unable to test my output in that method.
I also can use nix-repl
and load the flake and just import the default.nix file, but that seems, to put it bluntly, smelly.
Should I create a test system configuration in my flake and use that? I’ve read of dev-shells and things like that but it doesn’t seem like that’s the “bona fide” way of testing. I also tried looking into nixt
but that’s just… horribly broken.
