Hypridle ignoring system idle inhibit
this is not the idle_inhibitor on waybar.
I have noticed that hypridle will put my device to sleep even when some sort of inhibiting task is happening (like a video) for some reason the waybar idle_inhibitor is working fine.
using journalctl I found this: Apr 16 10:06:54 nixos hypridle[1817]: [LOG] Ignoring from onIdled(), inhibit locks: 1
I think this is related, but looking into the hypridle code, this seems to always be the case?
I think this is a home-manager issue more than a hypridle issue, I’ve had hyprland/hypridle on nixos before and this wasn’t a problem then. only difference now is I’m configuring it with home-manager.
this issue also happens in kde plasma though I nievely assumed it was still caused by hyridle
Apr 17 13:46:17 nixos dbus-daemon[1162]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
this tells me it’s something in the system itself that’s preventing idle inhibition. but I have no idea what it could be.
Did you try to set ignore_dbus_inhibit to false? It’s working fine for me with home-manager:
  services.hypridle = {
    settings = {
      general = {
        ignore_dbus_inhibit = false;
I did. It didn’t do anything, which makes sense, considering that the issue persists on KDE.
I’ve been thinking that I might have accidentally set an option to true in one of my nix files? I’ll try and get a GitHub repository open for people to check, but I haven’t found anything so far.
Don’t enable a service and have the same package in environment.systemPackages.
that’s what I did wrong, everything is fixed now.
This is proof that I am a noob.
