I need help in home-manager
I need help setting up home-manager, but it gives this OBNOXIOUS error i still cant fix
× home-manager-moe.service - Home Manager environment for moe
Loaded: loaded (/etc/systemd/system/home-manager-moe.service; enabled; preset: ignored)
Active: failed (Result: exit-code) since Fri 2026-07-31 12:37:27 MSK; 622ms ago
Invocation: 82b94d2c176743f5b187d9f441e92416
Process: 39959 ExecStart=/nix/store/jy0abkqvcnv63m7skj6ak06m0sv3sbks-hm-setup-env /nix/store/pnsx7cd8l28k7aa6ldggni3z40d4lc0i-home-manager-generation (code=exited, status=1/FAILURE)
Main PID: 39959 (code=exited, status=1/FAILURE)
IP: 0B in, 0B out
IO: 0B read, 0B written
Mem peak: 11.7M
CPU: 95ms
Jul 31 12:37:27 corb systemd[1]: Starting Home Manager environment for moe…
Jul 31 12:37:27 corb hm-activate-moe[39959]: Starting Home Manager activation
Jul 31 12:37:27 corb systemd[1]: home-manager-moe.service: Main process exited, code=exited, status=1/FAILURE
Jul 31 12:37:27 corb systemd[1]: home-manager-moe.service: Failed with result ‘exit-code’.
Jul 31 12:37:27 corb systemd[1]: Failed to start Home Manager environment for moe.
Command ‘systemd-run -E LOCALE_ARCHIVE -E NIXOS_INSTALL_BOOTLOADER -E NIXOS_NO_CHECK --collect --no-ask-password --pipe --quiet --service-type=exec --unit=nixos-rebuild-switch-to-configuration /nix/store/rxs5i1q80fbranwya87ijd2v1vk9x2y0-nixos-system-mako-26.11.20260723.e2587ca/bin/switch-to-configuration switch’ returned non-zero exit status 4.
i genuinely dont know what to do anymore, and maybe someone knows
I see you are using nixos module of home-manager. Could you check logs with journalctl --unit=home-manager-moe.service? And if you are going to post the output then it would be nice if you use tripple backticks
like this.
