I’m trying to use a flake to build an sd card image for a raspberry pi:
flake.nix
description = "";
nixos-generators = {
url = "github:nix-community/nixos-generators";
nixos-hardware.url = "github:NixOS/nixos-hardware/master";
outputs =
self,
nixpkgs,
nixos-generators,
nixos-hardware,
}@inputs:
rec {
packages.x86_64-linux = {
rpi = nixos-generators.nixosGenerate {
system = "aarch64-linux";
format = "sd-aarch64";
modules = [
./configuration.nix
nixos-hardware.nixosModules.raspberry-pi-4
This is the error I’m getting:
$ nix build .#rpi
warning: Git tree '/home/azani/projects/nixos_homelab' is dirty
error: builder for '/nix/store/m4qvgmwaklkv9g2h9y0g1v438j3w4q7z-config.txt.drv' failed with exit code 127;
last 1 log lines:
> /nix/store/shkw4qm9qcw5sc5n1k5jznc83ny02r39-default-builder.sh: line 1: genericBuild: command not found
For full logs, run:
nix log /nix/store/m4qvgmwaklkv9g2h9y0g1v438j3w4q7z-config.txt.drv
error: builder for '/nix/store/w9x9b9rfvzkj5si177p456ah5w4qiyha-install-extlinux-conf.sh.drv' failed with exit code 127;
last 1 log lines:
For full logs, run:
nix log /nix/store/w9x9b9rfvzkj5si177p456ah5w4qiyha-install-extlinux-conf.sh.drv
error: builder for '/nix/store/q7dwh3jin9id830nvhrmgz6lzgjv89r0-stage-2-init.sh.drv' failed with exit code 127;
last 1 log lines:
For full logs, run:
nix log /nix/store/q7dwh3jin9id830nvhrmgz6lzgjv89r0-stage-2-init.sh.drv
error: builder for '/nix/store/n0h28zsqzckhyzqb9137jf7rkd56l735-users-groups.json.drv' failed with exit code 127;
last 1 log lines:
For full logs, run:
nix log /nix/store/n0h28zsqzckhyzqb9137jf7rkd56l735-users-groups.json.drv
error: 1 dependencies of derivation '/nix/store/72bwa8iylfvvc44ilixgk7m56zh80v8h-nixos-image-sd-card-25.11.20250913.c23193b-aarch64-linux.img.zst.drv' failed to build
I’d love some help figuring out what is wrong. The flake works fine on my desktop but not on my laptop. I’m confused how that can happen.
