Hello,
I have a flake input (defined with haskell.nix), I’d like to embed in a docker container.
While, build it directly works:
nix build -L '.#packages.x86_64-linux.cabal-audit-static'
When I try to embed it;
# SPDX-FileCopyrightText: (C) Gautier DI FOLCO <gautier.difolco@gmail.com>
# SPDX-License-Identifier: ISC
description = "A Nix Flake for haskell-security-action";
cabal-audit.url = "github:mangoiv/cabal-audit";
outputs = { self, ... }@inputs:
supportedSystems = with inputs.flake-utils.lib.system;
x86_64-linux
#x86_64-darwin
#aarch64-linux
#aarch64-darwin
in inputs.flake-utils.lib.eachSystem supportedSystems (system:
let pkgs = import inputs.nixpkgs { inherit system; };
in rec {
packages.github-action-scan-image = pkgs.dockerTools.buildImage {
name = "blackheaven/haskell-security-action";
tag = "latest";
copyToRoot = pkgs.buildEnv {
name = "image-root";
paths =
[ inputs.cabal-audit.packages.${system}.cabal-audit-static ];
pathsToLink = [ "/bin" ];
config = { Cmd = [ "/bin/only-for-file-transfer" ]; };
defaultPackage = packages.github-action-scan-image;
devShell = pkgs.mkShell { };
It fails, as it tried to use my nixpkgs:
$ nix build -L
error:
at /builtin/derivation.nix:9:12: (source not available)
… while evaluating derivation 'cabal-audit-static-x86_64-unknown-linux-musl-1.0.0.0'
whose name attribute is located at /nix/store/h1v7aq3k9wy0i5l53cirm7kka7fsipji-source/pkgs/stdenv/generic/make-derivation.nix:336:7
… while evaluating attribute 'propagatedBuildInputs' of derivation 'cabal-audit-static-x86_64-unknown-linux-musl-1.0.0.0'
at /nix/store/h1v7aq3k9wy0i5l53cirm7kka7fsipji-source/pkgs/stdenv/generic/make-derivation.nix:390:7:
389| depsHostHostPropagated = elemAt (elemAt propagatedDependencies 1) 0;
390| propagatedBuildInputs = elemAt (elemAt propagatedDependencies 1) 1;
391| depsTargetTargetPropagated = elemAt (elemAt propagatedDependencies 2) 0;
error: attribute 'typst_0_5_0_3' missing
at /nix/store/h4vhpfsw6rbpclppr1bpk5l2hmjmpyp1-source/nix/haskell-overlay.nix:15:11:
14| sel = hlib.doJailbreak (hlib.markUnbroken hprev.sel);
15| typst = hprev.typst_0_5_0_3;
16| typst-symbols = hprev.typst-symbols_0_1_6;
Did you mean typst_0_5_0_5?
How can I simply embeds another input’s output, with it’s inputs, not mine?
Thanks in advance.
