The NixOS Manual describes a procedure for installing NixOS from another Linux distribution, which involves running some code as an ordinary user and some code as root
. However, when I follow this approach, nixos-install
fails, complaining it can’t find <nixpkgs/nixos>
(from what I remember) and suggesting to add the relevant directory to NIX_PATH
The procedure described in the manual involves setting NIX_PATH
for the nixos-install
invocation according to the value of NIX_PATH
that the ordinary user sees. However, NIX_PATH
is not set for the ordinary user. Still, running nix-instantiate --eval -E '<nixpkgs/nixos>'
as the ordinary user succeeds. Apparently, there is some additional magic that makes Nix find <nixpkgs/nixos>
when working as the ordinary user, but not when working as root
Could the manual please be fixed such that the description of how to install NixOS from another Linux distribution is correct again?
I quickly tried to install NixOS performing everything as root
, and at a first glance this seems to work. However, running in particular https://nixos.org/nix/install
as root
is not recommended. Is there any inherent problem with performing the whole installation as root
? I understand that you should minimize the amount of code executions as root
, but in my case the installation is performed from a rescue system, where there is not much to damage. Can I rely on a root
-only installation giving a correct result?
