Internal microphone not working: no input devices
Hi,
I have an HP EliteBook 640 G9, and the internal microphone is not working. In the Gnome sound settings menu in input devices, it only shows “no input devices”.
My configuration.nix is
  sound.enable = true;
  hardware.enableAllFirmware = true;
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
  # This made the sound works
  boot.extraModprobeConfig = ''
    options snd-intel-dspcfg dsp_driver=1
    sof-firmware
And here are outputs of some commands, i don’t know which might be relevant.
lspci| grep -i audio
00:1f.3 Multimedia audio controller: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC236 Analog [ALC236 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
lsmod | grep hda
snd_hda_codec_hdmi     94208  1
snd_hda_codec_realtek   200704  1
snd_hda_codec_generic   110592  1 snd_hda_codec_realtek
ledtrig_audio          12288  2 snd_ctl_led,snd_hda_codec_generic
snd_sof_intel_hda_common   241664  1 snd_sof_pci_intel_tgl
snd_soc_hdac_hda       28672  1 snd_sof_intel_hda_common
soundwire_intel        81920  1 snd_sof_intel_hda_common
snd_sof_intel_hda_mlink    36864  2 soundwire_intel,snd_sof_intel_hda_common
snd_sof_intel_hda      20480  1 snd_sof_intel_hda_common
snd_sof_pci            24576  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_sof_xtensa_dsp     16384  1 snd_sof_intel_hda_common
snd_sof               421888  3 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_hda
snd_hda_ext_core       36864  4 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_sof_intel_hda
snd_soc_acpi_intel_match    94208  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_sof_intel_hda_common
snd_soc_core          446464  4 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda
snd_hda_intel          65536  3
snd_intel_dspcfg       36864  3 snd_hda_intel,snd_sof,snd_sof_intel_hda_common
snd_intel_sdw_acpi     16384  2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_hda_codec         212992  6 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hda_core          139264  9 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_hwdep              20480  1 snd_hda_codec
snd_pcm               184320  12 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pcm_dmaengine
snd                   151552  21 snd_ctl_led,snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
led_class              20480  4 snd_hda_codec_generic,videodev,input_leds,iwlmvm
firmware_class         57344  12 btrtl,snd_hda_intel,xhci_pci_renesas,btmtk,snd_sof,drm_display_helper,btintel,btbcm,iwlwifi,btusb,i915,cfg80211
sudo fuser -v /dev/snd/*
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  work       2389 F.... pipewire
                     work       2393 F.... wireplumber
/dev/snd/pcmC0D0p:   work       2389 F...m pipewire
/dev/snd/seq:        work       2389 F.... pipewire
aplay -lL
null
    Discard all samples (playback) or generate zero samples (capture)
pipewire
    PipeWire Sound Server
default
    Default ALSA Output (currently PipeWire Media Server)
sysdefault:CARD=PCH
    HDA Intel PCH, ALC236 Analog
    Default Audio Device
front:CARD=PCH,DEV=0
    Front output / input
surround21:CARD=PCH,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
hdmi:CARD=PCH,DEV=3
    HDA Intel PCH, HDMI 3
    HDMI Audio Output
**** List of PLAYBACK Hardware Devices ****
  Subdevices: 0/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
amixer -c0
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 87
  Mono: Playback 69 [79%] [-13.50dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 252 [99%] [-0.60dB]
  Front Right: Playback 252 [99%] [-0.60dB]
Simple mixer control 'Mic Boost',0
  Capabilities: volume
  Capture channels: Front Left - Front Right
  Limits: 0 - 3
  Front Left: 2 [67%] [20.00dB]
  Front Right: 2 [67%] [20.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 39 [62%] [12.00dB] [on]
  Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
I also tried it on Pop!_OS live USB, and the mic works there. Here are the outputs of the same commands from the working Pop!_OS
pop-os@pop-os:~$ lspci| grep -i audio
pop-os@pop-os:~$ arecord -l
card 0: sofhdadsp [sof-hda-dsp], device 0: HDA Analog (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 1: HDA Digital (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 6: DMIC (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 7: DMIC16kHz (*) []
  Subdevices: 1/1
pop-os@pop-os:~$ lsmod |grep hda
snd_soc_skl_hda_dsp    24576  4
snd_soc_hdac_hdmi      45056  1 snd_soc_skl_hda_dsp
snd_soc_intel_hda_dsp_common    16384  1 snd_soc_skl_hda_dsp
snd_hda_codec_hdmi     98304  1
snd_hda_codec_generic   122880  1 snd_hda_codec_realtek
snd_hda_scodec_component    20480  1 snd_hda_codec_realtek
snd_sof_intel_hda_common   221184  1 snd_sof_pci_intel_tgl
soundwire_intel        73728  1 snd_sof_intel_hda_common
snd_sof_intel_hda_mlink    45056  2 soundwire_intel,snd_sof_intel_hda_common
snd_sof_intel_hda      24576  1 snd_sof_intel_hda_common
snd_sof_xtensa_dsp     12288  1 snd_sof_intel_hda_common
snd_sof               385024  4 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_probes,snd_sof_intel_hda
snd_soc_hdac_hda       24576  1 snd_sof_intel_hda_common
snd_soc_acpi_intel_match   102400  2 snd_sof_intel_hda_common,snd_sof_pci_intel_tgl
snd_soc_hda_codec      24576  1 snd_soc_avs
snd_hda_ext_core       32768  7 snd_soc_avs,snd_soc_hda_codec,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_sof_intel_hda
snd_soc_core          442368  10 snd_soc_avs,snd_soc_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_probes,snd_soc_dmic,snd_soc_skl_hda_dsp
snd_hda_intel          61440  0
snd_intel_dspcfg       36864  4 snd_soc_avs,snd_hda_intel,snd_sof,snd_sof_intel_hda_common
snd_hda_codec         204800  10 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_soc_intel_hda_dsp_common,snd_soc_hdac_hda,snd_sof_intel_hda,snd_soc_skl_hda_dsp
snd_hda_core          139264  13 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_intel_hda_dsp_common,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_soc_hdac_hda,snd_sof_intel_hda
snd_pcm               196608  13 snd_soc_avs,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pcm_dmaengine
snd                   143360  26 snd_ctl_led,snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_soc_hdac_hdmi,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
pop-os@pop-os:~$ sudo fuser -v /dev/snd/*
/dev/snd/controlC0:  pop-os     1509 F.... pipewire
                     pop-os     1511 F.... wireplumber
/dev/snd/seq:        pop-os     1509 F.... pipewire
pop-os@pop-os:~$ aplay -lL
null
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
hw:CARD=sofhdadsp,DEV=0
    sof-hda-dsp,
    Direct hardware device without any conversions
hw:CARD=sofhdadsp,DEV=1
    sof-hda-dsp,
hw:CARD=sofhdadsp,DEV=3
    sof-hda-dsp,
hw:CARD=sofhdadsp,DEV=4
    sof-hda-dsp,
hw:CARD=sofhdadsp,DEV=5
    sof-hda-dsp,
plughw:CARD=sofhdadsp,DEV=0
    sof-hda-dsp,
    Hardware device with all software conversions
plughw:CARD=sofhdadsp,DEV=1
    sof-hda-dsp,
plughw:CARD=sofhdadsp,DEV=3
    sof-hda-dsp,
plughw:CARD=sofhdadsp,DEV=4
    sof-hda-dsp,
plughw:CARD=sofhdadsp,DEV=5
    sof-hda-dsp,
sysdefault:CARD=sofhdadsp
    sof-hda-dsp,
dmix:CARD=sofhdadsp,DEV=0
    sof-hda-dsp,
    Direct sample mixing device
dmix:CARD=sofhdadsp,DEV=1
    sof-hda-dsp,
dmix:CARD=sofhdadsp,DEV=3
    sof-hda-dsp,
dmix:CARD=sofhdadsp,DEV=4
    sof-hda-dsp,
dmix:CARD=sofhdadsp,DEV=5
    sof-hda-dsp,
usbstream:CARD=sofhdadsp
    sof-hda-dsp
    USB Stream Output
  Subdevices: 1/1
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI1 (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 4: HDMI2 (*) []
  Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 5: HDMI3 (*) []
  Subdevices: 1/1
pop-os@pop-os:~$ amixer -c0
  Mono: Playback 87 [100%] [0.00dB] [on]
  Mono:
  Front Left: Playback 52 [60%] [-26.25dB] [off]
  Front Right: Playback 52 [60%] [-26.25dB] [off]
  Mono:
  Front Left: Playback 47 [54%] [-30.00dB] [on]
  Front Right: Playback 47 [54%] [-30.00dB] [on]
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
  Front Left: Capture 38 [60%] [11.25dB] [on]
  Front Right: Capture 38 [60%] [11.25dB] [on]
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Dmic0',0
  Limits: Capture 0 - 70
  Front Left: Capture 70 [100%] [20.00dB] [on]
  Front Right: Capture 70 [100%] [20.00dB] [on]
Simple mixer control 'Dmic1 2nd',0
  Front Left: Capture 50 [71%] [0.00dB]
  Front Right: Capture 50 [71%] [0.00dB]
Simple mixer control 'PGA1.0 1 Master',0
  Limits: Playback 0 - 32
  Mono:
  Front Left: Playback 32 [100%] [0.00dB]
  Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
  Limits: Capture 0 - 80
  Front Left: Capture 50 [62%] [0.00dB]
  Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA3.0 3 Master',0
  Mono:
Simple mixer control 'PGA4.0 4 Master',0
Simple mixer control 'PGA7.0 7 Master',0
  Mono:
Simple mixer control 'PGA8.0 8 Master',0
  Mono:
Simple mixer control 'PGA9.0 9 Master',0
  Mono:
I’m having the same problem, even including external USB mics and cannot for the life of me understand what is happening.
It was not like this and I believe it started sometime ago when there was some trouble with updates on the Linux kernel and it’s effect on pulse áudio. At the time I was able to fix the isso for audio outputs via some things in my config.
Pop!_OS is using sof-hda-dsp, here. Which might be still needed in your case.
I found this post, and I wonder if it’s still the same situation, where you have to blacklist the default modules and it will find the SOF ones. Possibly with hardware.enableAllFirmware = true;
