I’m using Ubuntu 22.04 and I have an very simple config file:
{ pkgs, ... }:
env.GREET = "hello";
packages = [ pkgs.jq ];
enterShell = ''
echo $GREET
jq --version
Then I active the shell, run simple jq command, everything is OK.
Then I run curl. I’m expecting to see command not found issue but the curl command success.
Ofc on the “host” I already have curl command installed. So is this normal behavior?
Any option to prevent this?
I want to prevent the issue that I forget to specific an command/tool/libs
