Hello,
I recently ran into https://github.com/NixOS/nixops-dashboard and was wondering if it was up for grabs?
If yes I’d be glad to begin this project.
Thanks
Hello,
Thanks
Probably yes.
But i would like Infor/LogicBlox to release their code, so the effort is not wasted and we can build upon that.
@edolstra can you ask if that is possible and what the status of the project is?
For reference: https://github.com/NixOS/nixops-dashboard/issues/1
Do they use NixOps?
Otherwise not sure that we could get the code from them.
If it is I’d suggest that we could set up some guidelines to be sure about what kind of project that we want.
https://github.com/NixOS/nixops-dashboard/issues/1#issuecomment-460685707 implies that they have something internally called nixops-dashboard.
Of course, it should be discussed what problem this project should solve and how.
How do you think we could start this?
