Still pretty green with NixOS. Switching to 24.05 X86_64 OpenGL works fine on my AMD laptop (for example, RADV Rembrandt) but 32-bit seems corrupted or missing. Both worked before in 23.11 with the same configuration.
Running Steam produces:
MESA-LOADER: failed to open radeonsi: /run/opengl-driver-32/lib/dri/radeonsi_dri.so: undefined symbol: amdgpu_va_get_start_addr (search paths /run/opengl-driver-32/lib/dri, suffix _dri)
MESA-LOADER: failed to open swrast: /run/opengl-driver-32/lib/dri/swrast_dri.so: undefined symbol: amdgpu_va_get_start_addr (search paths /run/opengl-driver-32/lib/dri, suffix _dri)
Which brings me to
ls -la /run/opengl-driver-32/lib/dri/
total 56388
dr-xr-xr-x 1 root root 536 Jan 1 1970 .
dr-xr-xr-x 1 root root 760 Jan 1 1970 ..
-r-xr-xr-x 2 root root 39438068 Jan 1 1970 crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 d3d12_dri.so -> crocus_dri.so
-r-xr-xr-x 2 root root 18232596 Jan 1 1970 d3d12_drv_video.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 i915_dri.so -> crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 iris_dri.so -> crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 kms_swrast_dri.so -> crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 nouveau_dri.so -> crocus_dri.so
lrwxrwxrwx 25 root root 18 Jan 1 1970 nouveau_drv_video.so -> d3d12_drv_video.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 r300_dri.so -> crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 r600_dri.so -> crocus_dri.so
lrwxrwxrwx 25 root root 18 Jan 1 1970 r600_drv_video.so -> d3d12_drv_video.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 radeonsi_dri.so -> crocus_dri.so
lrwxrwxrwx 25 root root 18 Jan 1 1970 radeonsi_drv_video.so -> d3d12_drv_video.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 swrast_dri.so -> crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 virtio_gpu_dri.so -> crocus_dri.so
lrwxrwxrwx 25 root root 18 Jan 1 1970 virtio_gpu_drv_video.so -> d3d12_drv_video.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 vmwgfx_dri.so -> crocus_dri.so
lrwxrwxrwx 73 root root 13 Jan 1 1970 zink_dri.so -> crocus_dri.so
using driversi686Linux.glxinfo I found a driver mismatch
LIBGL_DEBUG=verbose glxinfo -B
name of display: :0
libGL: Can't open configuration file /etc/drirc: No such file or directory.
libGL: Can't open configuration file /home/phi/.drirc: No such file or directory.
using driver amdgpu for 4
pci id for fd 4: 1002:1681, driver radeonsi
MESA-LOADER: dlopen(/run/opengl-driver-32/lib/dri/radeonsi_dri.so)
DRI driver not from this Mesa build ('23.1.9' vs '24.0.7')
failed to load driver: radeonsi
MESA-LOADER: dlopen(/run/opengl-driver-32/lib/dri/swrast_dri.so)
did not find extension DRI_Kopper version 1
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 150 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 46
Current serial number in output stream: 47
I also attempted to include driversi686Linux.mesa.drivers, but that fails to build
building '/nix/store/qd0gy6hh4f39jp6gylhgjbmv6ax5ykfy-opengl-drivers.drv'...
building '/nix/store/dqb8n7h0pximqxs7yfn91fzn6sy9hmcn-steam-run-usr-target.drv'...
building '/nix/store/lr1zdd498cjlxr73lavskdv1wb5bm0yq-steam-usr-target.drv'...
error: collision between `/nix/store/8x5kjwlvxxzjq3n28r1ibcj4am11jbd6-mesa-24.0.7-drivers/lib/d3d/d3dadapter9.so.1.0.0' and `/nix/store/hggpnywm6l7cfh2ml1ynm50ap9x4f9rn-mesa-24.0.7-drivers/lib/d3d/d3dadapter9.so.1.0.0'
warning: collision between `/nix/store/ci7gpws8432ilc8r557gbbbdkkgfgiqy-glibc-multi-2.39-52-bin/bin/ldconfig' and `/nix/store/6aqf6q0qvmqywc82rhnmny29li0ybbfh-ldconfig/bin/ldconfig'
warning: collision between `/nix/store/7cad4vjnvzrkbnm0vjg3mpxwh0cnnvn7-glibc-multi-2.39-52/lib/locale/locale-archive' and `/nix/store/hmy0ml9nw48c6znk3vn692m1pvk31k54-glibc-locales-2.39-52/lib/locale/locale-archive'
warning: collision between `/nix/store/c2i631h8i5vcs1sqifwxfsazhwrg6wr5-glibc-2.39-52-bin/bin/ldconfig' and `/nix/store/6aqf6q0qvmqywc82rhnmny29li0ybbfh-ldconfig/bin/ldconfig'
warning: collision between `/nix/store/c2i631h8i5vcs1sqifwxfsazhwrg6wr5-glibc-2.39-52-bin/bin/ldd' and `/nix/store/ci7gpws8432ilc8r557gbbbdkkgfgiqy-glibc-multi-2.39-52-bin/bin/ldd'
warning: collision between `/nix/store/k7zgvzp2r31zkg9xqgjim7mbknryv6bs-glibc-2.39-52/lib/locale/locale-archive' and `/nix/store/hmy0ml9nw48c6znk3vn692m1pvk31k54-glibc-locales-2.39-52/lib/locale/locale-archive'
error: builder for '/nix/store/qd0gy6hh4f39jp6gylhgjbmv6ax5ykfy-opengl-drivers.drv' failed with exit code 25
error: 1 dependencies of derivation '/nix/store/yvak4liywlfpppmhnbdqvbgpp1rg9b1l-nixos-tmpfiles.d.drv' failed to build
error: 1 dependencies of derivation '/nix/store/wbgd71clkw8yg1bhnzz9wjk8898zq2m6-tmpfiles.d.drv' failed to build
error: 1 dependencies of derivation '/nix/store/6mbga6ryfzvd9rmmy0l2hqx63xch4gz8-etc.drv' failed to build
error: 1 dependencies of derivation '/nix/store/97c0685575ajhrh6vfkjljxjas64gnaq-nixos-system-yoga-01-24.05.1695.dd457de7e08c.drv' failed to build
Steps To Reproduce
Steps to reproduce the behavior:
- Enable OpenGL as suggest at https://nixos.wiki/wiki/OpenGL
- Add channel for 24.05 and unpack
- Rebuild & Reboot
- Run steam in terminal
Expected behavior
AMD 32-bit 3D acceleration worked in 23.11, it should too in 24.05
Additional context
- Issue occurs on both Wayland and X11
- Also attempted setting amdvlk in
hardware.opengl.extraPackagesas suggested Appendix B. Release Notes, same result. - Also tested with nixos-hardware:common/gpu/amd (nixos-hardware/common/gpu/amd/default.nix at 083823b7904e43a4fc1c7229781417e875359a42 · NixOS/nixos-hardware · GitHub)
- Using nixos-hardware (nixos-hardware/lenovo/yoga/7/slim/gen8/default.nix at 083823b7904e43a4fc1c7229781417e875359a42 · NixOS/nixos-hardware · GitHub)
{ config, lib, pkgs, ... }:
options.hardware.amdgpu.loadInInitrd = lib.mkEnableOption (lib.mdDoc
"loading `amdgpu` kernelModule at stage 1. (Add `amdgpu` to `boot.initrd.kernelModules`)"
default = true;
config = lib.mkMerge [
services.xserver.videoDrivers = lib.mkDefault [ "modesetting" ];
hardware.opengl = {
driSupport = lib.mkDefault true;
driSupport32Bit = lib.mkDefault true;
(lib.mkIf config.hardware.amdgpu.loadInInitrd {
boot.initrd.kernelModules = [ "amdgpu" ];
Other relevant bits
hardware.opengl = {
driSupport = true;
driSupport32Bit = true;
programs.steam.enable = true;
boot.initrd.availableKernelModules = [ "nvme" "xhci_pci" "thunderbolt" "uas" "sd_mod" ];
boot.kernelModules = [ "kvm-amd" "amdgpu"];
Metadata
- system: `"x86_64-linux"`
- host os: `Linux 6.9.5, NixOS, 24.05 (Uakari), 24.05.1695.dd457de7e08c`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.18.2`
- channels(root): `"home-manager-24.05.tar.gz, nixos-24.05"`
- nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixos`
