$ home-manager switch
error: builder for '/nix/store/s31vlk12dslzkna3cncvg5a6636vyyf5-auto-fix-vscode-server.service.drv' failed to produce output path for output 'out' at '/nix/store/s31vlk12dslzkna3cncvg5a6636vyyf5-auto-fix-vscode-server.service.drv.chroot/nix/store/nhyc3xdqbw2gljn30y4wi2zwl1ki4mn1-auto-fix-vscode-server.service'
error: 1 dependencies of derivation '/nix/store/z02sq9nc2h1qw0vwayhzz594bir90iz1-home-manager-files.drv' failed to build
error: 1 dependencies of derivation '/nix/store/sxb36xzkgj7zp2ng8g3k7l9szxw108nl-home-manager-generation.drv' failed to build
The exact same config worked fine previously.
Has anyone encountered this before? Or have any idea how to fix it?
Lots of pieces of VSCode are broken as well. For example, trying to open the integrated terminal fails:
The terminal process failed to launch: A native exception occurred during launch (The module '/home/skainswo/.vscode-server/bin/30d9c6cd9483b2cc586687151bcbcd635f373630/node_modules/node-pty/build/Release/pty.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 93. This version of Node.js requires
NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).).
