Hello, I am having an issue. I tried setting up hibernate when my laptop lid is closed. Here are the settings.
When I open the lid nixos boots back up rather than resuming.
I found the related logs in journalctl -r.
Dec 12 08:51:20 n2 kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
Dec 12 08:51:20 n2 kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
Dec 12 08:51:20 n2 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Dec 12 08:51:20 n2 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Dec 12 08:51:20 n2 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Dec 12 08:51:20 n2 kernel: x86/split lock detection: warning about user-space split_locks
Dec 12 08:51:20 n2 kernel: Command line: initrd=\efi\nixos\9pzhkk8cpgl9yii33yx3sypqjbyj295y-initrd-linux-5.9.11-initrd.efi systemConfig=/nix/store/qqswaqqndkwjcvaqnczc7w5yqcw5lnlg-nixos-sys>
Dec 12 08:51:20 n2 kernel: Linux version 5.9.11 (nixbld@localhost) (gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.31.1) #1-NixOS SMP Tue Nov 24 12:39:15 UTC 2020
-- Reboot --
Dec 11 22:48:58 n2 kernel: PM: hibernation: hibernation entry
Dec 11 22:48:58 n2 systemd-sleep[16060]: Suspending system...
Dec 11 22:48:58 n2 kernel: PM: Image not found (code -22)
Dec 11 22:48:58 n2 dbus-daemon[872]: [system] Rejected send message, 7 matched rules; type="method_call", sender=":1.23" (uid=1000 pid=1645 comm="/run/current-system/sw/bin/xfce4-power-mana>
Dec 11 22:48:58 n2 pkexec[16050]: john: Executing command [USER=root] [TTY=unknown] [CWD=/] [COMMAND=/nix/store/5prb2zpjzk0pvi4cwbs90qiifdpxjk9f-xfce4-power-manager-1.6.6/sbin/xfpm-power-ba>
Dec 11 22:48:58 n2 pkexec[16050]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
Dec 11 22:48:58 n2 systemd[1]: Starting Hibernate...
Dec 11 22:48:58 n2 systemd[1]: Reached target Sleep.
Dec 11 22:48:58 n2 systemd[1]: Finished Pre-Sleep Actions.
Dec 11 22:48:58 n2 systemd[1]: pre-sleep.service: Succeeded.
Dec 11 22:48:58 n2 systemd[1]: Starting Pre-Sleep Actions...
Dec 11 22:48:56 n2 xserver-wrapper[1087]: (II) modeset(0): Modeline "1920x1200"x0.0 123.20 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (59.2 kHz e)
Dec 11 22:48:56 n2 xserver-wrapper[1087]: (II) modeset(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 -hsync -vsync (74.0 kHz eP)
Dec 11 22:48:56 n2 xserver-wrapper[1087]: (II) modeset(0): Printing DDC gathered Modelines:
Dec 11 22:48:56 n2 xserver-wrapper[1087]: (II) modeset(0): EDID vendor "SHP", prod id 5323
Dec 11 22:48:55 n2 wpa_supplicant[1092]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=9999 txrate=263300
Dec 11 22:48:55 n2 dbus-daemon[872]: [system] Rejected send message, 7 matched rules; type="method_call", sender=":1.23" (uid=1000 pid=1645 comm="/run/current-system/sw/bin/xfce4-power-mana>
Dec 11 22:48:55 n2 .xfdesktop-wrap[1632]: Failed to set the background '/nix/store/iw86sbad55jxgwpx1vwjr1apmzb8wcm0-xfdesktop-4.14.1/share/backgrounds/xfce/xfce-stripes.png': GDBus.Error:or>
Dec 11 22:48:55 n2 systemd-logind[871]: Lid closed.
Is there anything else I can post to see what the issue could be? There isn’t any logging of the hibernate process or any failure that I can see.
The computer is a dell xps 9300. My computer doesn’t have a swap partition. I chose to go with a swapfile similar to the way the ubuntu install had.
swapDevices = [
device = "/swapfile";
size = 34816;
I have 16 gigs of ram so this should be big enough for it. I will try digging more into it to see if I can find something. Thanks!
