Hello,
I am trying to package a python script of mine in a flake but I can’t get the runtime dependencies to work properly. The package depends on the python 3 packages pyserial
and paho-mqtt
, which are both in nixpkgs.
Building the flake succeeds but running the flake results in the error ModuleNotFoundError: No module named 'serial'
. I would greatly appreciate help in getting the modules correctly linked at runtime.
Here’s the layout of the repo:
├── flake.nix
├── README.md
├── setup.py
└── src
└── thruster_io_mqtt.py
setup.py:
from setuptools import setup
setup(
name='thruster-io-mqtt',
version='v1.1',
entry_points={
'console_scripts': ['thruster-io-mqtt = thruster_io_mqtt:main']
flake.nix:
description = "MQTT communication relay for ******";
inputs.nixpkgs.url = "nixpkgs/nixos-23.11";
outputs = { self, nixpkgs }:
allSystems = [
"x86_64-linux"
"aarch64-linux"
forAllSystems = f: nixpkgs.lib.genAttrs allSystems (system: f {
packages = forAllSystems ({ pkgs }: {
default = pkgs.python3Packages.buildPythonApplication rec {
pname = "thruster-io-mqtt";
src = self;
version = "v1.1";
propogatedBuildInputs = with pkgs.python3Packages; [
pyserial
paho-mqtt
doCheck = false;
