Hello everyone,
I recently installed NixOS on my Asus ROG Strix G513QM laptop, transitioning from a dual-boot setup to a single-boot configuration with NixOS. However, I’ve encountered a persistent issue during system shutdown where the process halts with the message: “kvm: Exiting hardware virtualization.”
Expected Outcome:
The laptop should shutdown when performing a shutdown from the OS.
Actual Outcome:
During shutdown, the process does not complete and stops at the message: “kvm: Exiting hardware virtualization.” Currently, the only workaround that partially addresses the issue is using the nomodeset kernel parameter, which isn’t ideal.
Steps Tried:
Installed Nvidia drivers through the NixOS hardware configurations using the predefined Asus settings (
<nixos-hardware/asus/rog-strix/g513im>). -
Attempted various configurations and tweaks suggested in forums and documentation, with no change in the shutdown behavior.
System Information (neofetch):
OS: NixOS 23.11.6418.e402c3eb6d88 (Tapir) x86_64
Kernel Version: 6.1.86
CPU: AMD Ryzen 7 5800H with Radeon Graphics (16) @ 3.200GHz
GPU 1: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
GPU 2: NVIDIA GeForce RTX 3060 Mobile / Max-Q
I am new to NixOS, so detailed guidance on how to diagnose and possibly fix this issue would be highly appreciated. If more information is needed, I am ready to provide it.
Thank you in advance for your assistance!
