I’ve been working on packaging the Wazuh agent over the last couple of weeks. It is something I’ve wanted to see done for a bit, and there is already an existing packaging request for it. I’ve been around Nix for a bit now but this is my first foray into this level of complexity so there is probably plenty to be improved.
Package Request: Package request: wazuh-agent · Issue #230623 · NixOS/nixpkgs · GitHub
My Fork: nixpkgs/pkgs/tools/security/wazuh/default.nix at 2faa23610cdcc573ef366ebf556cfd178738b48e · sjdwhiting/nixpkgs · GitHub
I’ve worked through quite a few issues already to get to this point but I’m a stuck on this error which might be more of a cmake problem than a nix one.
[100%] Linking CXX executable ../bin/sysinfo_test_tool
Reaping winning child 0x47f7f0 PID 59268
cd /nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/data_provider/build/testtool && /nix/store/ih9mk4l2rr9sd10rkmyjm38fn2ysypl0-cmake-3.27.7/bin/cmake -E cmake_link_script CMakeFiles/sysinfo_test_tool.dir/link.txt --verbose=
Live child 0x47f7f0 (bin/sysinfo_test_tool) PID 59269
/nix/store/3z013mdl9cvpgvavpj19rbilihz4clvi-binutils-2.40/bin/ld: /nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/libwazuhext.so: undefined reference to `ZSTD_versionNumber'
/nix/store/3z013mdl9cvpgvavpj19rbilihz4clvi-binutils-2.40/bin/ld: /nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/libwazuhext.so: undefined reference to `ZSTD_createDStream'
/nix/store/3z013mdl9cvpgvavpj19rbilihz4clvi-binutils-2.40/bin/ld: /nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/libwazuhext.so: undefined reference to `ZSTD_decompressStream'
/nix/store/3z013mdl9cvpgvavpj19rbilihz4clvi-binutils-2.40/bin/ld: /nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/libwazuhext.so: undefined reference to `ZSTD_isError'
/nix/store/3z013mdl9cvpgvavpj19rbilihz4clvi-binutils-2.40/bin/ld: /nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/libwazuhext.so: undefined reference to `ZSTD_freeDStream'
collect2: error: ld returned 1 exit status
Reaping losing child 0x47f7f0 PID 59269
make[4]: *** [testtool/CMakeFiles/sysinfo_test_tool.dir/build.make:98: bin/sysinfo_test_tool] Error 1
Removing child 0x47f7f0 PID 59269 from chain.
Reaping losing child 0x473ee0 PID 59263
make[3]: *** [CMakeFiles/Makefile2:126: testtool/CMakeFiles/sysinfo_test_tool.dir/all] Error 2
Removing child 0x473ee0 PID 59263 from chain.
Reaping losing child 0x483490 PID 59198
make[2]: *** [Makefile:101: all] Error 2
Removing child 0x483490 PID 59198 from chain.
make[2]: Leaving directory '/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/data_provider/build'
Reaping losing child 0x57cda0 PID 59011
make[1]: *** [Makefile:1673: build_sysinfo] Error 2
Removing child 0x57cda0 PID 59011 from chain.
make[1]: Leaving directory '/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src'
Reaping losing child 0x585500 PID 58977
make: *** [Makefile:813: agent] Error 2
Removing child 0x585500 PID 58977 from chain.
error: builder for '/nix/store/9hsk409fjcqd5cd3pv2w05fsvr8nzx7d-wazuh-agent-4.7.3.drv' failed with exit code 2;
last 10 log lines:
For full logs, run 'nix-store -l /nix/store/9hsk409fjcqd5cd3pv2w05fsvr8nzx7d-wazuh-agent-4.7.3.drv'.
I’ve tracked it down to this tool: wazuh/src/data_provider/testtool at master · wazuh/wazuh · GitHub
However, I wasn’t able to sort out where zstd
is actually being referenced in any of the CMake related files.
This is the link.txt
file that is being referenced.
/nix/store/ihhhd1r1a2wb4ndm24rnm83rfnjw5n0z-gcc-wrapper-12.3.0/bin/g++ -g -Wall -Wextra -Wshadow -Wnon-virtual-dtor -Woverloaded-virtual -Wunused -Wcast-align -Wformat=2 -std=c++14 -O3 -s CMakeFiles/sysinfo_test_tool.dir/main.cpp.o -o ../bin/sysinfo_test_tool -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/sqlite -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/cJSON -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/procps -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/bzip2 -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/libplist/bin/lib -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/libdb/build_unix -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/pacman/lib/libalpm -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/libarchive/.libs -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/rpm/builddir -L/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/openssl -Wl,-rpath,/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/sqlite:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/cJSON:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/procps:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/bzip2:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/libplist/bin/lib:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/libdb/build_unix:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/pacman/lib/libalpm:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/libarchive/.libs:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/rpm/builddir:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/external/openssl:/nix/store/4kykj1h5c9f2g7kipdazqp21vc4kbxrx-wazuh-agent-4.7.3/src/data_provider/build/lib ../lib/libsysinfo.so -ldl -lpthread -lproc -lwazuhext
So far, this problem seems isolated to this particular sysinfo
tool. I went back through the logs and other linking operations executed just fine. The big mystery seems to be where these references to zstd are actually happening. I had naively hoped that just adding zstd to the buildInputs would fix it.
So my actual question is, how do I fix this! If there is any other useful information I can provide, please let me know and I’ll gladly get it. Any and all help is appreciated.
