Issues with RDP Connection from Remmina to KDE Remote Desktop (Wayland)
Hi,
I’m running two NixOS machines, both using the unstable channel with KDE 6 on Wayland. I’m trying to use Remmina to RDP from my main machine to a target machine, which has KDE’s built-in remote desktop server enabled.
When I try to connect, the target machine shows a notification saying, “Remote session started, requested access to input device and screens,” but nothing actually happens on the Remmina side, the connection doesn’t go through. I also tried the KDE remote client, but it was even worse.
For context:
  • Firewall: I don’t need to worry about open ports as I’m using Tailscale, but I’ve opened the necessary RDP ports anyway for troubleshooting, and it didn’t help.
  • OS: Both machines are running NixOS with the unstable channel, and both are using KDE 6 with Wayland.
Here’s the debug log from Remmina if anyone needs more details. Any help or suggestions would be greatly appreciated!
This window can help you find connection problems.
You can stop and start the logging at any moment using the On/Off switch.
The stats button (Ctrl+T), can be useful to gather system info you may share when reporting a bug.
There is more info about debugging Remmina on https://gitlab.com/Remmina/Remmina/-/wikis/Usage/Remmina-debugging
(DEBUG) - (rcw_map_event) - Mapping: RemminaConnectionWindow
(DEBUG) - (remmina_protocol_widget_map_event) - Calling plugin mapping function
(DEBUG) - (remmina_protocol_widget_open_connection_real) - Opening connection
(DEBUG) - (remmina_rdp_event_init) - Disable smooth scrolling is set to 0
(DEBUG) - (remmina_rdp_event_init) - Adding GDK_SMOOTH_SCROLL_MASK
(DEBUG) - (remmina_protocol_widget_open_connection_real) - Have SSH
(DEBUG) - (remmina_rdp_main) - RDP data path is /home/user/.local/share/remmina/RDP
(DEBUG) - (remmina_rdp_main) - Not using system proxy settings
(DEBUG) - (remmina_rdp_tunnel_init) - Tunnel init
(DEBUG) - (remmina_protocol_widget_start_direct_tunnel) - SSH tunnel initialization…
(DEBUG) - (remmina_protocol_widget_start_direct_tunnel) - Calling remmina_public_get_server_port
(DEBUG) - (remmina_protocol_widget_start_direct_tunnel) - Calling remmina_public_get_server_port (tunnel)
(DEBUG) - (remmina_protocol_widget_start_direct_tunnel) - server: 100.126.27.50, port: 3389
(DEBUG) - (remmina_rdp_tunnel_init) - protocol_plugin_start_direct_tunnel() returned [100.126.27.50]:3389
(DEBUG) - (remmina_rdp_tunnel_init) - Tunnel has been optionally initialized. Now connecting to 100.126.27.50:3389
(DEBUG) - (remmina_rdp_main) - gfx_h264_available: 1
(DEBUG) - (remmina_rdp_main) - Resolution set by the user: 1704x1084
(DEBUG) - (remmina_rdp_main) - Resolution set after workarounds: 1704x1084
(DEBUG) - (remmina_rdp_main) - proxy_type: (null)
(DEBUG) - (remmina_rdp_main) - proxy_username: (null)
(DEBUG) - (remmina_rdp_main) - proxy_password: (null)
(DEBUG) - (remmina_rdp_main) - proxy_hostname: (null)
(DEBUG) - (remmina_rdp_main) - proxy_port: 80
(DEBUG) - (remmina_rdp_main) - Network settings not set
(DEBUG) - (remmina_rdp_main) - rdp_keyboard_remapping_list:
(DEBUG) - (remmina_rdp_main) - Log level set to to INFO
(DEBUG) - (remmina_rdp_event_on_clipboard) - gp=0x21ccb10: owner-change event received
(DEBUG) - (remmina_rdp_event_on_clipboard) - gp=0x21ccb10 owner-change: new owner is different than me: new=(nil) me=0x21ccb10
(DEBUG) - (remmina_rdp_event_on_clipboard) - gp=0x21ccb10 owner-change: new owner is not me: Sending local clipboard format list to server.
(DEBUG) - (remmina_rdp_cliprdr_get_client_format_list) - gp=0x21ccb10 sending to server the following local clipboard content formats
(DEBUG) - (remmina_rdp_cliprdr_get_client_format_list) -      local clipboard format text/plain will be sent to remote as 1
(DEBUG) - (remmina_rdp_cliprdr_get_client_format_list) -      local clipboard format text/plain;charset=utf-8 will be sent to remote as 13
(DEBUG) - (rco_on_disconnect) - Disconnect signal received on RemminaProtocolWidget
(DEBUG) - (remmina_file_save) - Saving profile
(DEBUG) - (remmina_file_save) - We have a secret and disablepasswordstoring=0
(DEBUG) - (remmina_file_save) - Profile saved
(DEBUG) - (remmina_file_save) - Connection profile states saved
(DEBUG) - (remmina_network_monitor_status) - G_NETWORK_CONNECTIVITY_FULL
(DEBUG) - (rco_on_disconnect) - Could not disconnect
Have you tried xrdp on the remote host?
https://nixos.wiki/wiki/Remote_Desktop#RDP
  services.xrdp = {
    openFirewall = true;
  services.xrdp = {
    # to replace with KDE session manager
    defaultWindowManager = "gnome-session";
Also note that some features aren’t working as expected with wayland on Remmina (e.g multiple monitors).
Isn’t xrdp for, well, x?
I prefer to find a solution for Wayland, as I have no desire to switch back to X11.
It’s not just Remmina that won’t connect, it’s also KRDC.
@waffle8946
yeah my bad :joy:
@SudoMason
Can you screenshot your config on Remmina to access the host?
I recall having some issues with Gnome + Wayland with it and some feat were not working as expected (e.g multi-monitors).
Have you tried a different client? Remote Desktop - NixOS Wiki
Maybe kdrc and kdrp on host?
I switched to KRDC and it’s the same problem. It will recognize the certificate on my client machine and also shows a notification on the target machine that a remote session has started but nothing actually happens.
