jaxlibWithCuda not using CUDA
Hello,
I’ve been trying to set up an environment with Jax and CUDA. My shell.nix is as follows, though I’ve tried variants:
{ pkgs ? import <nixpkgs> { } }:
pkgs.mkShell {
  buildInputs = with pkgs; [
   cudatoolkit
   python3
   python3Packages.jax
   python3Packages.jaxlibWithCuda
   python3Packages.huggingface-hub
   python3Packages.datasets
   python3Packages.wandb
   python3Packages.equinox
   python3Packages.optax
In the nix shell, nvidia-smi shows my GPU as expected. However, jaxlib seems to be compiled as CPU-only, despite my use of jaxlibWithCuda:
[nix-shell:~/Projects/ML/ramen]$ python -c 'import jax; print(jax.devices())'
An NVIDIA GPU may be present on this machine, but a CUDA-enabled jaxlib is not installed. Falling back to cpu.
[CpuDevice(id=0)]
In my configuration.nix, I have:
  services.xserver.videoDrivers = ["nvidia"];
  hardware.opengl = {
    driSupport = true;
    driSupport32Bit = true;
  hardware.nvidia = {
    modesetting.enable = true;
    open = false;
    nvidiaSettings = true;
  nixpkgs.config.cudaSupport = true;
  systemd.services.nvidia-control-devices = {
    serviceConfig.ExecStart = "${pkgs.linuxPackages.nvidia_x11.bin}/bin/nvidia-smi";
Does anyone know what could be causing this?
Update:
Replacing the first line with { pkgs ? import <nixpkgs> { config.allowUnfree = true; config.cudaSupport = true } }: causes it to perform a lot of tests.
However, the same error persists, although now wandb must be removed since it fails some tests.
I am having the same issue. With nixos-23.11, jaxlibWithCuda seems to have some issue. I got
>>> import jax
>>> jax.devices()
[CpuDevice(id=0)]
I am having the same issue. I also tried the master branch of nixpkgs, but it still did not work.
According to this issue a fix was just merged in nixpkgs/master, there’s also a workaround in the comments explaining how to use jax-bin instead.
Yup, should be fixed now! Sorry for the trouble everyone. Do let me know if you still have issues!
