However, as I moved to Niri, it crashes on start. Running joplin-desktop in the terminal, shows this error:
Sentry: Initialized with autoUploadCrashDumps: false
[18692:0120/220624.507626:ERROR:ui/ozone/platform/x11/ozone_platform_x11.cc:250] Missing X server or $DISPLAY
[18692:0120/220624.507659:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
zsh: segmentation fault (core dumped) joplin-desktop
My understanding is that Joplin should work on Wayland, so, what’s going on here?
the error implies this application uses X. in wayland, that would be handled using Xwayland.
niri has some documentation on how they recommend handling that.
on NixOS, i handled that like this.
in the event you installed Niri using the external niri-flake, they offer an option to handle this.
Thank you!
I feel like my solution is similar?
I will double-check your file in the morning to better understand what’s different. However, it works now, so, I might not change it anyway because if it’s not broken and all of that
yours makes the application use wayland, which is what you want, if possible.
mine is a fallback for applications that do not support wayland natively, but need X.
