I updated kitty to the version from the unstable channel (0.30.1) because version 0.28.1 was acting out under wayland (didn’t read keycodes correctly).
The update solved the problem, however i now get this in kitty:
~ sudo -i
doas (sperber@nixos) password:
doas: TERMINFO=/nix/store/444jzask4nm2i9vgih417mnfwlzzvd9i-kitty-0.30.1/lib/kitty/terminfo: command not found
If i use another terminal or the older version of kitty then this does not occur and everything works as expected, so i suspect a problem with the package.
@tex @rvolosatovs @Luflosi @adamcstephens could you please take a look at this?
