Laptop 13 + NixOS: issues with wifi card & linux kernel (xpad-noone module)
Hi,
(NB: this post is a rough duplicate of this one on framework’s discourse. I will update both once these issues are -hopefully :)- fixed.)
I’m running NixOS 25.11 with KDE Plasma on a Framework Laptop 13 w/ AMD Ryzen AI 7 350 & Radeon 850M. The firmware is up to date.
I’ve been running NixOS on the Laptop 13 without serious issues since ~ June 2025, pretty happy about it so far!
TL;DR:
My system is currently plagued by - as far as I can tell - at least two different issues, one related to a kernel module (xpad-noone) not supported by my version of NixOS, the other one related to a serious instability of the wifi card. My system is barely usable right now and any help would be much appreciated. Thanks in advance for reading this waaaay too long post :slight_smile:
The first issue: xpad-noone preventing a proper rebuild
Since a few days, NixOS rebuild doesn’t succeed. It seems to be related to a module coming with Linux latest kernel, xpad-noone.
My up to date configuration is available at https://git.sr.ht/\~mapper/nixos-fixable . Rebuilding the config first failed after this commit. Here’s the output of the nixos-rebuild switch command:
$ sudo nixos-rebuild switch --flake -v
debug: nixos_rebuild.process: calling run with args=['nix', '--extra-experimental-features', 'nix-command flakes', 'build', '--print-out-paths', '.#nixosConfigurations."fixable".config.system.build.nixos-rebuild', '-v', '--no-link'], kwargs={'stdout': -1}, extra_env=None
debug: nixos_rebuild.process: captured output with stdout='/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11\n', stderr=None
debug: nixos_rebuild.process: calling run with args=['nix', '--extra-experimental-features', 'nix-command flakes', 'build', '--print-out-paths', '.#nixosConfigurations."fixable".config.system.build.toplevel', '--no-link', '-v'], kwargs={'stdout': -1}, extra_env=None
these 15 derivations will be built:
  /nix/store/pi3mg3c9i70aznip92124cf86wapf8vq-xpad-noone-0-unstable-2024-01-10.drv
  /nix/store/f0mrn00jrd68qh47wly3989vk0ypwfkf-linux-6.18-modules.drv
  /nix/store/1zvbc7y4xiwmhyqdwiplzbb3x1fp7v1c-linux-6.18-modules-shrunk.drv
  /nix/store/12wxdr8j0d2l9p7wad72234fmn25q0s1-closure-info.drv
  /nix/store/jcdkhm08a6pmd8lva8smdxlvi6vcbzvs-home-manager-path.drv
  /nix/store/1msb33b9r7019cqxs8jjdsy1qmrd2whl-hm_fontconfigconf.d10hmfonts.conf.drv
  /nix/store/yjavp2wl7739d845vrcn8vsw08j03y9m-initrd-linux-6.18.drv
  /nix/store/2ij0bp3zw43f0zm9pshfpgkgymirk6pm-boot.json.drv
  /nix/store/nkl6jbdrxzgahh31sgz8440w9nlhm73w-user-environment.drv
  /nix/store/fc1k9vyhfv7xyljs4ynyhkrbbjjj8zqc-home-manager-files.drv
  /nix/store/6r9x3w79s2q6g5wsfdyxasiyw400wpck-home-manager-generation.drv
  /nix/store/kd98py36v6rz21cpdz8hsmb34vs6r762-unit-home-manager-jeremy.service.drv
  /nix/store/nw1k4vbck35d5jpil3a40yvz4q0lhl4h-system-units.drv
  /nix/store/3mrl7dxsl1ris82jrd5vpmmfzl7z9c1z-etc.drv
  /nix/store/b4vfd8wrs79mhzlx62i8gf5dams4i45j-nixos-system-fixable-25.11.20251206.d9bc5c7.drv
building '/nix/store/pi3mg3c9i70aznip92124cf86wapf8vq-xpad-noone-0-unstable-2024-01-10.drv'...
building '/nix/store/jcdkhm08a6pmd8lva8smdxlvi6vcbzvs-home-manager-path.drv'...
error: Cannot build '/nix/store/pi3mg3c9i70aznip92124cf86wapf8vq-xpad-noone-0-unstable-2024-01-10.drv'.
       Reason: builder failed with exit code 2.
       Output paths:
         /nix/store/9dy39w67651sc0849gkdckkqgrl68jc2-xpad-noone-0-unstable-2024-01-10
       Last 25 log lines:
       > source root is source
       > Running phase: patchPhase
       > Running phase: updateAutotoolsGnuConfigScriptsPhase
       > Running phase: configurePhase
       > no configure script, doing nothing
       > Running phase: buildPhase
       > build flags: SHELL=/nix/store/rlq03x4cwf8zn73hxaxnx0zn5q9kifls-bash-5.3p3/bin/bash CC=/nix/store/kzq78n13l8w24jn8bx4djj79k5j717f1-gcc-14.3.0/bin/gcc LD=/nix/store/dc9vaz50jg7mibk9xvqw5dqv89cxzla3-binutils-2.44/bin/ld AR=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/ar NM=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/nm STRIP=/nix/store/dc9vaz50jg7mibk9xvqw5dqv89cxzla3-binutils-2.44/bin/strip OBJCOPY=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/objcopy OBJDUMP=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/objdump READELF=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/readelf HOSTCC=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/cc HOSTCXX=/nix/store/vr15iyyykg9zai6fpgvhcgyw7gckl78w-gcc-wrapper-14.3.0/bin/c++ HOSTAR=/nix/store/xwydcyvlsa3cvssk0y5llgdhlhjvmqdm-binutils-wrapper-2.44/bin/ar HOSTLD=/nix/store/xwydcyvlsa3cvssk0y5llgdhlhjvmqdm-binutils-wrapper-2.44/bin/ld ARCH=x86_64 CROSS_COMPILE= KBUILD_OUTPUT=/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/build
       > make -C /nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/build M=/build/source modules
       > make[1]: Entering directory '/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/build'
       > make[2]: Entering directory '/build/source'
       >   CC [M]  xpad.o
       > xpad.c: In function 'xpad_led_probe':
       > xpad.c:1144:24: error: implicit declaration of function 'ida_simple_get' [-Wimplicit-function-declaration]
       >  1144 |         xpad->pad_nr = ida_simple_get(&xpad_pad_seq, 0, 0, GFP_KERNEL);
       > xpad.c:1167:9: error: implicit declaration of function 'ida_simple_remove' [-Wimplicit-function-declaration]
       >  1167 |         ida_simple_remove(&xpad_pad_seq, xpad->pad_nr);
       > make[4]: *** [/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/source/scripts/Makefile.build:287: xpad.o] Error 1
       > make[3]: *** [/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/source/Makefile:2010: .] Error 2
       > make[2]: *** [/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/source/Makefile:248: __sub-make] Error 2
       > make[2]: Leaving directory '/build/source'
       > make[1]: *** [/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/source/Makefile:248: __sub-make] Error 2
       > make[1]: Leaving directory '/nix/store/pyix2bwixdp8yw4qlhqv5xsxygyf6nhy-linux-6.18-dev/lib/modules/6.18.0/build'
       > make: *** [Makefile:4: all] Error 2
       For full logs, run:
         nix log /nix/store/pi3mg3c9i70aznip92124cf86wapf8vq-xpad-noone-0-unstable-2024-01-10.drv
error: Cannot build '/nix/store/f0mrn00jrd68qh47wly3989vk0ypwfkf-linux-6.18-modules.drv'.
       Reason: 1 dependency failed.
       Output paths:
         /nix/store/6xd2bf8skcz2bkn3hxzdd10m6rd6g4jx-linux-6.18-modules
error: Cannot build '/nix/store/b4vfd8wrs79mhzlx62i8gf5dams4i45j-nixos-system-fixable-25.11.20251206.d9bc5c7.drv'.
       Output paths:
         /nix/store/7hza6czriigqdb2ajv4z31pbiwhy4vpr-nixos-system-fixable-25.11.20251206.d9bc5c7
  File "/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/__init__.py", line 352, in main
    execute(sys.argv)
  File "/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/__init__.py", line 315, in execute
    services.build_and_activate_system(
        action=action,
    ...<6 lines>...
        grouped_nix_args=grouped_nix_args,
  File "/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/services.py", line 301, in build_and_activate_system
    path_to_config = _build_system(
        attr=attr,
    ...<5 lines>...
  File "/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/services.py", line 173, in _build_system
    path_to_config = nix.build_flake(
        attr,
    ...<2 lines>...
        | grouped_nix_args.flake_build_flags,
  File "/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/nix.py", line 87, in build_flake
    r = run_wrapper(run_args, stdout=PIPE)
  File "/nix/store/vvfclqlzrwsbmk015rwysvqrp7dmir03-nixos-rebuild-ng-25.11/lib/python3.13/site-packages/nixos_rebuild/process.py", line 137, in run_wrapper
    r = subprocess.run(
        run_args,
    ...<7 lines>...
        **kwargs,
  File "/nix/store/3lll9y925zz9393sa59h653xik66srjb-python3-3.13.9/lib/python3.13/subprocess.py", line 577, in run
    raise CalledProcessError(retcode, process.args,
                             output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['nix', '--extra-experimental-features', 'nix-command flakes', 'build', '--print-out-paths', '.#nixosConfigurations."fixable".config.system.build.toplevel', '--no-link', '-v']' returned non-zero exit status 1.
I’ve added a comment to a ticket on nixpkgs Github to help fixed this upstream issue. As I tried to downgrade the kernel (cf. the git history of my nixos config), another issue arose, seemingly a big instability of the wifi card management by the system.
The second issue: wifi instability
Here are the symptoms:
  • At login, the system freezes before I can enter my credentials. I have two or three seconds to login before it freezes;
  • If I succeed to login, once I’m in the session, the wifi applet doesn’t launch. Networks seem available but there’s no way to connect to it. Here are a couple screenshots:
    Copie d'écran_20251208_154414
    Copie d'écran_20251208_154434
My wifi card is a MediaTek MT7925.
Here’s the output of a couple of commands that will hopefully give more context:
  • NetworkManager status
$ systemctl status NetworkManager
● NetworkManager.service - Network Manager
     Loaded: loaded (/etc/systemd/system/NetworkManager.service; enabled; preset: ignored)
    Drop-In: /nix/store/01xkm431dzb8gcsb9vy77ja8mvhb346b-system-units/NetworkManager.service.d
             └─NetworkManager-ovs.conf, overrides.conf
     Active: active (running) since Wed 2025-12-10 07:57:45 CET; 55min ago
 Invocation: 1a17565a6cad4a34b7fc708e0dd24180
       Docs: man:NetworkManager(8)
   Main PID: 1842 (NetworkManager)
         IP: 18.1K in, 48B out
         IO: 7.6M read, 24K written
      Tasks: 4 (limit: 76052)
     Memory: 12.6M (peak: 16.5M)
        CPU: 3.308s
     CGroup: /system.slice/NetworkManager.service
             └─1842 /nix/store/h91szsp5bk28zddrdp3y0bpl7nx9pkj4-networkmanager-1.54.1/sbin/NetworkManager --no-daemon
déc. 10 07:57:43 fixable systemd[1]: Starting Network Manager...
déc. 10 07:57:45 fixable systemd[1]: Started Network Manager.
  • ip link
$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: wlp192s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
    link/ether d8:b3:2f:bd:c2:81 brd ff:ff:ff:ff:ff:ff
    altname wlxd8b32fbdc281
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
    link/ether be:71:e3:e9:74:ae brd ff:ff:ff:ff:ff:ff
  • lsusb
$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix Fingerprint USB Device
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 32ac:001c Framework Laptop Webcam Module (2nd Gen)
Bus 003 Device 003: ID 0e8d:0717 MediaTek Inc. Wireless_Device
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 002: ID 32ac:0005 Framework 1TB Expansion Card
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  • lspci | grep -i wireless doesn’t return anything.
That’s it!
Do any of you have experienced similar issues? Is there any known fix that I could apply?
Once again, any help would be much appreciated. Thank you!
Not quite, it’s that you’re using a third party kernel module with a non-LTS kernel. Just don’t do this.
That, or disable this: https://git.sr.ht/~mapper/nixos-fixable/tree/master/item/configuration.nix#L231
If I had to guess, that module might also be the culprit as far as your stability goes, but the framework forum is likely better equipped to debug that.
Ha! I knew the issue was coming from the chair-screen interface, I just couldn’t figure it out properly. :person_facepalming:
It turns out I previously messed with this param while trying out musnix, and apparently didn’t revert things properly. Regarding the xone parameter, not sure why it was true since the first commit.
Thanks! :slight_smile:
