Ld: framework not found System
After prematurely posting my last question I’m now facing an issue I really can’t solve. I’m trying to package the Solana CLI and you can find my current efforts here GitHub - cideM/solana-nix: The Solana CLI tools packaged up with Nix
I’m on a MacBook.
If I run nix build I get
   Compiling serde_derive v1.0.130
   Compiling serde v1.0.130
   Compiling memchr v2.4.0
   Compiling spin v0.5.2
error: linking with `/nix/store/jgaarpq3rdfk7gbm0gm3xlh8hhbw15ay-clang-wrapper-11.1.0/bin/cc` fai
  = note: "/nix/store/jgaarpq3rdfk7gbm0gm3xlh8hhbw15ay-clang-wrapper-11.1.0/bin/cc" "-arch" "arm6
  = note: ld: framework not found System
          clang-11: error: linker command failed with exit code 1 (use -v to see invocation)
error: aborting due to previous error
error: could not compile `proc-macro2`
I’ve already read most issues and PRs on that topic and so far I have this in the flake:
            nativeBuildInputs = [
              pkgs.hidapi
              pkgs.llvmPackages.clang
              pkgs.llvm
              pkgs.rustfmt
              pkgs.darwin.apple_sdk.frameworks.System
              pkgs.llvmPackages.libclang
              pkgs.pkg-config
            buildInputs = [
              pkgs.hidapi
              pkgs.llvm
              pkgs.rustfmt
              pkgs.openssl
              # pkgs.udev
              pkgs.zlib
            preBuild = ''
              export LLVM_CONFIG_PATH="${pkgs.llvm}/bin/llvm-config";
              export LIBCLANG_PATH="${pkgs.llvmPackages.libclang.lib}/lib";
            preConfigure = ''
              export NIX_LDFLAGS="-F${pkgs.darwin.apple_sdk.frameworks.System}/Library/Frameworks -framework System $NIX_LDFLAGS";
so as you can see I already have the frameworks.System and I’m passing it via NIX_LDFLAGS but it doesn’t change the error in any way.
The solution to this issue is to make sure that whatever application you are linking/compiling is not linking to System.
The System framework should never be used according to Apple: https://developer.apple.com/library/archive/documentation/MacOSX/Conceptual/OSX_Technology_Overview/SystemFrameworks/SystemFrameworks.html
So the best thing to do is to patch the software.
I had this issue with compiling a Rust project. It is definitely a Nix-Darwin thing. I had no problem compiling the project with cargo build in my system. I also had no problem using nix-build inside a docker image with aarch-unknown-linux-gnu
Did anyone find a solution to this? I’m getting what I assume is a related problem, but with SystemConfiguration when trying to add datafusion-cli:
   >   = note: ld: framework not found SystemConfiguration
   >           clang-16: error: linker command failed with exit code 1 (use -v to see invocation)
   > error: could not compile `datafusion-cli` (bin "datafusion-cli") due to 1 previous error
with the following in my flake.nix:
      buildInputs = [
          openssl
          pkg-config
          cargo-dist
          llvmPackages_latest.llvm
          llvmPackages_latest.bintools
          zlib.out
          llvmPackages_latest.lld
          darwin.apple_sdk.frameworks.Security
          darwin.apple_sdk.frameworks.SystemConfiguration
          datafusion-cli
          (rust-bin.selectLatestNightlyWith (toolchain: toolchain.default.override {
            extensions = [ "rust-src" "rust-analyzer" ];
        shellHook = ''
          export NIX_LDFLAGS="-F${pkgs.darwin.apple_sdk.frameworks.SystemConfiguration}/Library/Frameworks -framework SystemConfiguration $NIX_LDFLAGS"
          alias ls=exa
          alias find=fd
          alias grep=ripgrep
Facing similar issue
error: could not compile `prisma-cli` (bin "prisma-cli") due to 1 previous error
These are the build inputs that I needed in order to resolve my linker errors for a rust project I am working on
buildInputs =
            # Add additional build inputs here
            pkgs.openssl
            pkgs.pkg-config
          ++ lib.optionals pkgs.stdenv.isDarwin [
            # Additional darwin specific inputs can be set here
            pkgs.libiconv
