Legacy software issue? - stm32cubemx and java
Hello, I’m relatively new to nixos but am looking to get it set up with an older piece of software. I’m hoping to be able to replicate these setup across 3 computers.
The sticking point has been to get stm32cubemx set up, using an older version of it.
nixpkgs contains a more recent version, which is great and will get used, also we need the ‘legacy’ version for old project files.
the typical command to start the installer is
$ java -jar SetupSTM32CubeMX-4.27.0.exe
(I know, strange enough already)
I hit an error when it’s attempting to install, error executing chmod?? pretty basic stuff…
Screenshot from 2020-12-29 03-26-07
Running with sudo makes no difference.
I’ve tried different versions fo Java, the latest attempt being a 32-bit version - that had many more errors cropping up in the terminal.
since the older cubemx installers are behind a login wall I’ll include this here in case someone want to try reproduce the error.
from: STM32CubeMX - STM32Cube initialization code generator - STMicroelectronics
It’s unlikely that the installer will work without using buildFHSUserEnv. See NixOS - Nixpkgs 21.05 manual).
Have you tried modifying the stm32cubemx Nix package so that it uses the older version you need?
The former looks like it could be a useful way to put a working solution in parallel with configuration.nix, correct?
Or I could modify the Nix package and keep that version on a personal repo… this option seems easier possibly… assuming the older files are available from ST. I’m unsure if that is the case.
How would I be able to get the details of the Nix package so that I can have a look inside it?
look inside it?
You can go to
https://search.nixos.org/packages?channel=20.09&show=stm32cubemx&from=0&size=30&sort=relevance&query=stm32cubemx
to find the package, and then click on the link to the nix expression:
https://github.com/NixOS/nixpkgs/blob/e065200fc90175a8f6e50e76ef10a48786126e1c/pkgs/development/tools/misc/stm32cubemx/default.nix
If you want to know, this error seem to be caused due to the non-existence of the /bin/chmod file (software should use the PATH environment to determine it’s location).
Also, somethings usefull to determine how to use an older version is git history: just click the history icon on github, and you will have a list of revision for this file (were we can see the first version in nixpkgs is 5.3.0). Also, keep in mind that you need to replace/remove the hash, as if the hash doesn’t change, it’ll use the older version that is in the cache.
I’ve ascertained the correct version is on the server through the same url the nix expression is using…
. https://sw-center.st.com/packs/resource/library/stm32cube_mx_v4270.zip
How do I go about changing the SHA-256? Done.
How do install using this new default.nix I’ll make? ( or any .nix ???) Done
and How would this take shape in configuration.nix for the other systems to follow?
Cheers
Got it.
I downloaded and decompressed the target zip to get a hash of the folder:
$ nix-hash --type sha256 stm32cube_mx_v4270
and then followed this guide to install stm32cubemx
. Nixpkgs/Create and debug packages - NixOS Wiki
stm32cubemx installed and running, just need to push my change to my forked repo of the pkgs and point configuration.nix to my repo for stm32cubemx… gotta figure that one out…
Anyone got an idea on how to beautify this one?
I have an override at the top of my configuration.nix
Seems a bit messy. Also, desktopItem doesn’t override either. I’d like to change desktopName but I’m stuck with the default.
{ config, pkgs, ... }:
  stm32cubemx427 = pkgs.stm32cubemx.overrideAttrs(oldAttrs: rec {
      name = "stm32cubemx";
      version = "4.27.0";
  desktopItem = pkgs.makeDesktopItem {
    name = "stm32CubeMX";
    exec = "stm32cubemx";
    desktopName = "STM32CubeMX427";
    categories = "Development;";
    icon = "stm32cubemx";
      src = pkgs.fetchzip {
      url = "https://sw-center.st.com/packs/resource/library/stm32cube_mx_v${builtins.replaceStrings ["."] [""] version}.zip";
      sha256 = "3c383ec23f07c2a5a6f0b0e40c853bae9e11475719598bff96fa5b74b410badc";
      stripRoot= false;
  imports =
      ./hardware-configuration.nix
  # Boot
  networking.hostName = "nixoshpprobook"; # Define your hostname.
  # Set your time zone.
  time.timeZone = "Europe/London";
  # The global useDHCP flag is deprecated, therefore explicitly set to false here.
  # Per-interface useDHCP will be mandatory in the future, so this generated config
  # replicates the default behaviour.
  networking.useDHCP = false;
  networking.interfaces.enp0s25.useDHCP = true;
  networking.interfaces.wlo1.useDHCP = true;
  i18n.defaultLocale = "en_GB.UTF-8";
  # console = {
  #   font = "Lat2-Terminus16";
  #   keyMap = "us";
  # Enable the GNOME 3 Desktop Environment.
  services.xserver.desktopManager.gnome3.enable = true;
  # Configure keymap in X11
  services.xserver.layout = "gb";
  # services.xserver.xkbOptions = "eurosign:e";
  # Enable sound.
  sound.enable = true;
  hardware.pulseaudio.enable = true;
  users.users.d4 = {
    isNormalUser = true;
    extraGroups = [ "wheel" "dialout" ]; # Enable ‘sudo’ for the user.
  # $ nix search wget
     wget nano
     firefox tor-browser-bundle-bin
     vscode platformio git
     gparted ntfs3g exfat apfs-fuse
     stm32flash gcc-arm-embedded gnumake
     nmap-graphical
     python3 gcc_latest
     adoptopenjdk-jre-openj9-bin-8
     eagle kicad
     inkscape gimp
     stm32cubemx427
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # Enable the OpenSSH daemon.
  services.avahi.enable = true;
  services.avahi.nssmdns = true;
  # Open ports in the firewall.
  system.stateVersion = "20.09"; # Did you read the comment?
I was able to build this from my nur repo here. What you could do is add the package to a separate .nix file and use callPackage.
stm32cubemx-4_27_0 = callPackage ./pkgs/stm32cubemx {};
replace ./pkgs/stm32cubemx with the location of your .nix file.
I wouldn’t suggest using overrideAttrs in this case but it is up to you. If you are installing multiple versions of the same project then it may be needed. I just discovered this with the jdk today.
