I tried it, but it didn’t work. It spat out errors that i already solved. I tried adding inputsFrom to the shell (same error as before) and replacing BuildInputs with InputsFrom (no python interpreter?) nonetheless Thank you.
/nix/store/lkgfphix3sgfsm38smsw38xk81h3f3ig-glibc-2.40-66-bin/bin/ldconfig: Can't open cache file /nix/store/vbrdc5wgzn0w1zdp10xd2favkjn5fk7y-glibc-2.40-66/etc/ld.so.cache
: No such file or directory
2025-04-21 15:03:36,650: ['/nix/store/lkgfphix3sgfsm38smsw38xk81h3f3ig-glibc-2.40-66-bin/bin/ldconfig', '-p'] command failed: Command '['/nix/store/lkgfphix3sgfsm38smsw38xk81h3f3ig-glibc-2.40-66-bin/bin/ldconfig', '-p']' returned non-zero exit status 1.
File "/home/mirko/BigProjects/lutris/./bin/lutris", line 62, in <module>
from lutris.gui.application import Application # pylint: disable=no-name-in-module
File "/home/mirko/BigProjects/lutris/lutris/gui/application.py", line 45, in <module>
from lutris.gui.dialogs.delegates import CommandLineUIDelegate, InstallUIDelegate, LaunchUIDelegate
File "/home/mirko/BigProjects/lutris/lutris/gui/dialogs/delegates.py", line 10, in <module>
from lutris.services import get_enabled_services
File "/home/mirko/BigProjects/lutris/lutris/services/__init__.py", line 6, in <module>
from lutris.services.amazon import AmazonService
File "/home/mirko/BigProjects/lutris/lutris/services/amazon.py", line 25, in <module>
from lutris.services.base import SERVICE_LOGIN, OnlineService
File "/home/mirko/BigProjects/lutris/lutris/services/base.py", line 20, in <module>
from lutris.gui.views.media_loader import download_media
File "/home/mirko/BigProjects/lutris/lutris/gui/views/media_loader.py", line 5, in <module>
from lutris.gui.widgets.utils import MEDIA_CACHE_INVALIDATED
File "/home/mirko/BigProjects/lutris/lutris/gui/widgets/utils.py", line 13, in <module>
from lutris.util import datapath, magic, system
File "/home/mirko/BigProjects/lutris/lutris/util/magic.py", line 227, in <module>
libmagic = ctypes.CDLL(dll)
File "/nix/store/fqm9bqqlmaqqr02qbalm1bazp810qfiw-python3-3.12.9/lib/python3.12/ctypes/__init__.py", line 379, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libmagic.so.1: cannot open shared object file: No such file or directory
edit: I changed buildInputs to packages and nothing changed
edit 2: When I remove packages and only use inputsFrom it doesnt work because i don’t even have a python interpreter
2025-04-21 15:12:02,630: ['/nix/store/lkgfphix3sgfsm38smsw38xk81h3f3ig-glibc-2.40-66-bin/bin/ldconfig', '-p'] command failed: Command '['/nix/store/lkgfphix3sgfsm38smsw38xk81h3f3ig-glibc-2.40-66-bin/bin/ldconfig', '-p']' returned non-zero exit status 1.
Error importing Lutris application module: failed to find libmagic. Check your installation
