Librewolf settings and extentions
Hi all,
suddenly my declaration for Librewolf stopped working - only a vanilla Librewolf will be deployed. I try to declare some settings and install extensions with the following config:
  programs.firefox = {
    package = pkgs.librewolf;
    policies = {
      DisableTelemetry = true;
      DisableFirefoxStudies = true;
      Preferences = {
        "cookiebanners.service.mode.privateBrowsing" = 2; # Block cookie banners in private browsing
        "cookiebanners.service.mode" = 2; # Block cookie banners
        "network.cookie.lifetimePolicy" = 0;
        "privacy.clearOnShutdown.cookies" = false;
        "privacy.clearOnShutdown.history" = false;
        "privacy.donottrackheader.enabled" = true;
        "privacy.fingerprintingProtection" = true;
        "privacy.resistFingerprinting" = false;
        "privacy.trackingprotection.emailtracking.enabled" = true;
        "privacy.trackingprotection.enabled" = true;
        "privacy.trackingprotection.fingerprinting.enabled" = true;
        "privacy.trackingprotection.socialtracking.enabled" = true;
        "webgl.disabled" = false;
      ExtensionSettings = {
        "addon@darkreader.org" = {
          install_url = "https://addons.mozilla.org/firefox/downloads/latest/darkreader/latest.xpi";
          installation_mode = "force_installed";
        "vimium-c@gdh1995.cn" = {
          install_url = "https://addons.mozilla.org/firefox/downloads/latest/vimium-c/latest.xpi";
        "authenticator@mymindstorm" = {
          install_url = "https://addons.mozilla.org/firefox/downloads/latest/auth-helper/latest.xpi";
        "FirefoxColor@mozilla.com" = {
          install_url = "https://addons.mozilla.org/firefox/downloads/latest/firefox-color/latest.xpi";
        "idcac-pub@guus.ninja" = {
          install_url = "https://addons.mozilla.org/firefox/downloads/latest/istilldontcareaboutcookies/latest.xpi";
Any idea if there is something wrong with my config? I also tried to switch to home manager config, but there you cannot install any extensions, to my knowledge.
I don’t think there’s anything wrong with your config but you should try using Home Manager to configure it as it’s exactly the same but with a bit more options and see if it works. You can install extensions aswell on Home Manager. My config is at GitHub - xNyfPtx/nix-config.
