I’m currently trying Nix and nix-direnv for a small toy project in C with SDL2.
My shell.nix
file looks like this:
with pkgs;
mkShell {
nativeBuildInputs = [
gcc
SDL2
SDL2_ttf
Everything was working fine at first when I was just using the SDL2
package but when I started to include SDL2_ttf
I encountered an error during the compilation:
$ make
gcc -std=c99 ./src/*.c `sdl2-config --cflags --libs` -lm -o raycast;
/nix/store/3r87a2wq1w4l66wnsm7rqvy608mx23h6-binutils-2.40/bin/ld: /tmp/ccarNoZM.o: in function `initializeWindow':
main.c:(.text+0x17): undefined reference to `TTF_Init'
collect2: error: ld returned 1 exit status
make: *** [Makefile:2: build] Error 1
In case you’re wondering, sdl2-config
does find my libs correctly:
$ sdl2-config --cflags --libs
-I/nix/store/qp9jcxmnd1z3cjf2lqh88m4pr8iykzg3-SDL2-2.26.5-dev/include/SDL2 -I/nix/store/qp9jcxmnd1z3cjf2lqh88m4pr8iykzg3-SDL2-2.26.5-dev/include/SDL2 -I/nix/store/qm5i5h35lgcqxy9rsbpllrv5q0zsl4hy-SDL2_ttf-2.20.2/include/SDL2 -I/nix/store/qp9jcxmnd1z3cjf2lqh88m4pr8iykzg3-SDL2-2.26.5-dev/include/SDL2 -I/nix/store/qm5i5h35lgcqxy9rsbpllrv5q0zsl4hy-SDL2_ttf-2.20.2/include/SDL2 -I/nix/store/qp9jcxmnd1z3cjf2lqh88m4pr8iykzg3-SDL2-2.26.5-dev/include/SDL2 -I/nix/store/qm5i5h35lgcqxy9rsbpllrv5q0zsl4hy-SDL2_ttf-2.20.2/include/SDL2 -D_REENTRANT
-L/nix/store/nqgj705lic1qf8jz6x42bbhkw6dh38n1-SDL2-2.26.5/lib -Wl,-rpath,/nix/store/nqgj705lic1qf8jz6x42bbhkw6dh38n1-SDL2-2.26.5/lib -Wl,--enable-new-dtags -lSDL2
In my code I did #include <SDL2/SDL_ttf.h>
correctly but the error seems to come from inside the SDL_ttf.h
file when it tries to #include "SDL.h"
: https://github.com/libsdl-org/SDL_ttf/blob/3a51231c98ab0ca728bba6eb5f743da5dcfedf5a/SDL_ttf.h#L39. At this point the folder contains only SDL_ttf.h
so it cannot link to SDL.h
Since I’m new to this I don’t understand if I missed something to make the two packages work together correctly. Are there any example of projects using nix-direnv and SDL2 correctly?
