Hi ![]()
I got a weird issue after latest upgrade: Wifi (intel/iwlwifi) stopped working. After checking dmesg, I saw the error no suitable firmware found!in it. If I remove the module and re-load with modprobe, it works again.
Here is the relevant dmesg output, which you can see it starts with usual warnings after some time when I do the reload:
[ 1.536573] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 1.538853] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x1080800 wfpm id 0x80000020
[ 1.538856] iwlwifi 0000:00:14.3: PCI dev 7e40/4090, rev=0x441, rfid=0x2010d000
[ 1.538858] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz
[ 1.538892] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-ma-b0-gf-a0-89.ucode failed with error -2
[ 1.538898] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 1.538900] iwlwifi 0000:00:14.3: iwlwifi-ma-b0-gf-a0-89 is required
[ 1.538902] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
[ 52.436006] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x1080800 wfpm id 0x80000020
[ 52.436019] iwlwifi 0000:00:14.3: PCI dev 7e40/4090, rev=0x441, rfid=0x2010d000
[ 52.436022] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz
[ 52.444878] iwlwifi 0000:00:14.3: loaded firmware version 89.df9556fc.0 ma-b0-gf-a0-89.ucode op_mode iwlmvm
[ 52.723163] iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
[ 52.723204] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 52.723225] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 52.723232] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 52.723241] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 52.723257] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[ 52.724029] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 52.806115] iwlwifi 0000:00:14.3: base HW address: 6c:f6:da:3f:71:db
[ 52.832149] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[ 53.003552] iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
[ 53.003609] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 53.003623] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 53.003629] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 53.003638] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 53.004287] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 53.296498] iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
[ 53.296621] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 53.296644] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 53.296650] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x80
[ 53.296657] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 53.297370] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
I don’t have any changes in my config, and always had linux-firmware installed (hardware.firmware = [pkgs.linux-firmware]and hardware.enableRedistributableFirmware = true).
Is there a recent change which broke my old config, e.g. a new option which I should use instead? I tried to check latest commits on nixpkgs but nothing strike me as direct suspect, so I am not sure if this should be a github issue instead.
Thanks!
