I am so glad to see llama-index included in nixpkgs unstable. I am curious if any of you have managed to get it working, and would have a recipe for doing so.
My first attempt was simply to add the package llama-index
. But that collides with llama-index-cli
, so I tried llama-index-core
instead and that works fine.
I did need to set the environment variable NLTK_DATA
so that nltk would not attempt to write to the nix store.
It feels like there are other gotchas, though, with llama-index not playing well with the read-only store. For instance, after a call to VectorStoreIndex.from_documents
, I receive Read-only file system: '/nix/store/zlsx2pa9mhp1rvnq575hqpdgffip3vr8-python3-3.12.2-env/lib/python3.12/site-packages/llama_index/core/_static/tiktoken_cache/9b5ad71b2ce5302211f9c61530b329a4922fc6a4.addd3212-e92b-4c65-9d5b-cd081afd8099.tmp'
Are there other recommended llama-index settings or environment variables others have used to keep llama-index from attempting to write to the nix store?
