I get an error Exception=Failed to create new thread when trying to build packages that rely on the Lazarus compiler.
Originally I was trying to create a PR for goverlay, but the build kept failing. I noticed that the Lazarus compiler had an update, so I created a draft pr for it. When I run nixpkgs-review, all the builds that depend on it fail.
I have been trying to debug this for a few hours and am completely stumped, please let me know if you have any ideas or if I can give more information.
I got this same problem also with doublecmd, , what I found out is that nix-rebuild is constrained with perf settings - I had problems with build hogging cpu, and I tired to set idle for build, but it lead to problems, so I disabled it
# disabled 20260204 lazarus couldnt make thread
# daemonCPUSchedPolicy = "other"; # the idle policy may greatly improve responsiveness of a system performing expensive builds
# daemonIOSchedClass = "best-effort"; #
# daemonIOSchedPriority = 7;
this is what i have now, but this settings are newest, i dont remember if I tried new rebuild, safer is to try first class = “batch”;
