A long time ago I changed from z̶s̶h̶ ̶t̶o̶ ̶f̶i̶s̶h̶ fish to zsh. On one computer this worked. On the other (shared import in configuration.nix file), the shell did not change, and yet the value seems correctly set:
tyler@sol ~> nix repl
Welcome to Nix version 2.3.1. Type :? for help.
nix-repl> :l <nixos>
Added 11057 variables.
nix-repl> :l <nixpkgs/nixos>
Added 6 variables.
nix-repl> config.users.users.tyler.shell
«derivation /nix/store/mjsi2g0lgxxizd71rni924xq7rwn0zhm-zsh-5.7.1.drv»
Fish is my default shell when I open Konsole. Do I need to manually chsh to zsh? (seems like I shouldn’t have to…)
Eek typo in first sentence should have said “A long time ago I changed from fish to zsh”. I’ve noticed that when I ssh in, I get a zsh shell as expected, but in konsole I get a fish shell. I’ll try deleting ~/.cache when back on that computer
When I boot, /etc/shells does not list zsh. When I do sudo nixos-rebuild switch, zsh now appears in /etc/zsh. When I reboot, zsh is no longer in /etc/shells.
Edit: mutableUsers is false. I’ve now removed fish entirely from my configuration.nix and home.nix, and yet it still appears on my system. When I do switch and open a new shell, I get dumped into sh as /run/current-system/aw/bin/fish could not be found. This is despite /etc/passwd showing zsh as my shell! And on reboot, fish is back, and all changes to /etc/shells and /etc/passwd are reverted!! It’s like I have a fish rootkit lol wtf is happening.
Edit 2: even chsh fails:
> chsh -s /run/current-system/sw/bin/zsh
Password:
Cannot change ID to root.
Edit3: after switch and logout, login is to zsh. However on reboot fish has magically reappeared. Something seems horribly wrong with my nixos
I had a similar problem and found the solution on this reddit post, if anyone’s wondering. You need to set environment.shells = [ pkgs.zsh ] and enable it as well. Should work
