Man Pages for Grub2 seems missing for Nixos?
Hi,
My knowledge of Linux is much longer but my experience of Nixos is about a year and I have a question about man pages for grub2.
I am currently on version 24.5
I have installed grub2 packages by adding it to configuration.nix and expected man pages to follow with the packages, but it didn’t. Am I missing something in my configuration?
To be more specifc I have installed the package by adding grub2 in configuration.nix like
this:
{ config, lib, pkgs, … }:
environment.systemPackages = with pkgs;[
grub2
man-pages
man-pages-posix
documentation = {
dev.enable = true;
man.generateCaches = true;
nixos.includeAllModules = true;
and running from shell:
nixos-rebuild test
typing
man grub-install
No manual entry for grub-install.
Anyone knows if man pages exist for Nixos at all?
Might be missing. Would you be interested in contributing a fix?
Thank you @mightyiam for your reply. Certainly if I could I would. I am not a programmer though but more like a sys-admin.I have no idea how that fix would look like, but I was personally more curious and interested in if I had followed the procedure correctly for installing the package after using nixos search to find out about the package; and I understand also I can install ubuntu or Mint on a VM and read the manpages there for grub2 if in need.
Fix is coming in a couple of days to nixos-unstable:
And the backport PR for 24.05 is created as well:
Thanks @waffle8946 for your fix. Much appreciated!
