Thanks for responding, Polygon! Is your config online? If it helps, here’s mine:
https://github.com/JeffreyBenjaminBrown/nixos-experiments/tree/5751ecde294f8409253762d6ea4ba8eff0786d31/config
That’s a permalink to the latest, still-experimental commit that includes the part of your code that didn’t yield a conflict with musnix for me, described below.
Futzing with paths
musnix already defines LV2_PATH = makePluginPath "lv2";, which yields a conflict when I try using your LV2_PATH = "/run/current-system/sw/lib/lv2";. (It has a bunch of similar definitions:
DSSI_PATH = makePluginPath "dssi";
LADSPA_PATH = makePluginPath "ladspa";
LXVST_PATH = makePluginPath "lxvst";
VST_PATH = makePluginPath "vst";
VST3_PATH = makePluginPath "vst3";
I don’t understand it, but I added your
pathsToLink = [
"/lib/vst2" "/lib/vst3" "/lib/clap" "lib/lv2" ];
to my config and rebuilt.
When I evaluate LV2_PATH in Bash I see
[jeff@jbb-hp24-oled:~]$ echo $LV2_PATH
/home/jeff/.nix-profile/lib/lv2:/run/current-system/sw/lib/lv2:/etc/profiles/per-user/jeff/lib/lv2:/home/jeff/.lv2
No stable/unstable mixing.
I don’t even know how to mix stable and unstable packages. All my packages are from nixpkgs 24.11.
ldd results
[jeff@jbb-hp24-oled:~/.lv2/drumgizmo/lib/lv2/drumgizmo.lv2]$ ldd drumgizmo.so
linux-vdso.so.1 (0x00007f7250727000)
libX11.so.6 => /nix/store/ikjw6a952jd9wn5k06mkj710xzabssr0-libX11-1.8.10/lib/libX11.so.6 (0x00007f725040f000)
libXext.so.6 => /nix/store/d5y0sl4vwsb9m99r18zh1mx4fw9y70g6-libXext-1.3.6/lib/libXext.so.6 (0x00007f72503fa000)
libsndfile.so.1 => /nix/store/v3mh7x9nhnicg7mkb1r1xmcjjkpyflr3-libsndfile-1.2.2/lib/libsndfile.so.1 (0x00007f725036d000)
libpthread.so.0 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libpthread.so.0 (0x00007f7250368000)
libatomic.so.1 => /nix/store/ybjcla5bhj8g1y84998pn4a2drfxybkv-gcc-13.3.0-lib/lib/../lib64/libatomic.so.1 (0x00007f725035b000)
librt.so.1 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/librt.so.1 (0x00007f7250356000)
libstdc++.so.6 => /nix/store/ybjcla5bhj8g1y84998pn4a2drfxybkv-gcc-13.3.0-lib/lib/../lib64/libstdc++.so.6 (0x00007f7250000000)
libm.so.6 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libm.so.6 (0x00007f725026f000)
libc.so.6 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libc.so.6 (0x00007f724fe07000)
libgcc_s.so.1 => /nix/store/ybjcla5bhj8g1y84998pn4a2drfxybkv-gcc-13.3.0-lib/lib/../lib64/libgcc_s.so.1 (0x00007f724fde2000)
libxcb.so.1 => /nix/store/w63ks7mg1dsgm2gg302ss70wpq7g0l4d-libxcb-1.17.0/lib/libxcb.so.1 (0x00007f724fdb6000)
libFLAC.so.12 => /nix/store/9nk7ym5kg8rf3v3rxw7yxfbckk120h99-flac-1.4.3/lib/libFLAC.so.12 (0x00007f724fd34000)
libvorbis.so.0 => /nix/store/bnl8rhs4324hpzk6ik5c4wnz4dz89smg-libvorbis-1.3.7/lib/libvorbis.so.0 (0x00007f724fcf9000)
libvorbisenc.so.2 => /nix/store/bnl8rhs4324hpzk6ik5c4wnz4dz89smg-libvorbis-1.3.7/lib/libvorbisenc.so.2 (0x00007f724fc4d000)
libopus.so.0 => /nix/store/8000ndhxf2ppjw91r3r25dr9yhvjgy8w-libopus-1.5.2/lib/libopus.so.0 (0x00007f724fbe5000)
libogg.so.0 => /nix/store/j2h0qmkjw72p6nh27ii97r9wq042l4ca-libogg-1.3.5/lib/libogg.so.0 (0x00007f724fbda000)
libmpg123.so.0 => /nix/store/yv263ja8gcwsi2hfzqf32rsy5qjhz8r7-libmpg123-1.32.8/lib/libmpg123.so.0 (0x00007f724fb7b000)
libmp3lame.so.0 => /nix/store/qa6xya7klldgfhmjvlspg35xb3srgdqm-lame-3.100-lib/lib/libmp3lame.so.0 (0x00007f724fb01000)
/nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib64/ld-linux-x86-64.so.2 (0x00007f7250729000)
libXau.so.6 => /nix/store/ighb6h0x1nv14ap2fj0j3bqdn0x3xra4-libXau-1.0.11/lib/libXau.so.6 (0x00007f7250264000)
libXdmcp.so.6 => /nix/store/8jqc1bpk99jgib12wgpdjmnbndrmg7vz-libXdmcp-1.1.5/lib/libXdmcp.so.6 (0x00007f724faf9000)
libmvec.so.1 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libmvec.so.1 (0x00007f724fa00000)
[jeff@jbb-hp24-oled:~/.lv2/Pianoteq 8.lv2]$ ldd Pianoteq_8.so
linux-vdso.so.1 (0x00007f0c45704000)
librt.so.1 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/librt.so.1 (0x00007f0c456f9000)
libdl.so.2 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libdl.so.2 (0x00007f0c456f4000)
libfreetype.so.6 => not found
libstdc++.so.6 => not found
libm.so.6 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libm.so.6 (0x00007f0c42b19000)
libmvec.so.1 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libmvec.so.1 (0x00007f0c42a20000)
libgcc_s.so.1 => /nix/store/2d5spnl8j5r4n1s4bj1zmra7mwx0f1n8-xgcc-13.3.0-libgcc/lib/libgcc_s.so.1 (0x00007f0c456cd000)
libpthread.so.0 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libpthread.so.0 (0x00007f0c456c8000)
libc.so.6 => /nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib/libc.so.6 (0x00007f0c42827000)
/nix/store/wn7v2vhyyyi6clcyn0s9ixvl7d4d87ic-glibc-2.40-36/lib64/ld-linux-x86-64.so.2 (0x00007f0c45706000)
