Microphone Not Detected - System76 Pangolin
Hi, Nix newbie here. I’ve recently bought the System76 Pangolin and installed NixOS straight away. I’ve had a lot of fun tinkering and setting up my workspaces, but one thing I have not been able to figure out is how to enable my microphone. It works properly in the Pop!_OS installation USB, but I can’t figure out how to get my NixOS setup to detect it. I believe that the problem is related to the output of arecord -l. Here’s the output I get on the Pop!_OS installation medium:
pop-os@pop-os:~$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: Generic_1 [HD-Audio Generic], device 0: CX11970 Analog [CX11970 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 2: acp6x [acp6x], device 0: DMIC capture dmic-hifi-0 []
  Subdevices: 0/1
and here’s what I get from NixOS:
[isaac:~]$ arecord -l
  Subdevices: 1/1
Obviously, the missing piece is card 2: acp6x. Anyone know how I can get this working? My audio output is working just fine. Thanks in advance :slight_smile:
Edit: Here’s my full configuration.nix:
# your system. Help is available in the configuration.nix(5) man page
{ config, lib, pkgs, ... }:
	i3-modifier = "Mod4";
		imports = [
			./hardware-configuration.nix
			<home-manager/nixos>
			<nixos-hardware/system76>
		boot.loader = {
			systemd-boot.enable = true;
			authy
			chromium
			glances
			gnumake
			lightlocker
			lxqt.lxqt-policykit
			nixpkgs-fmt
			pavucontrol
			shutter
			spotify
			thunderbird
			wget
		hardware = {
			bluetooth.enable = true;
			bluetooth.settings = {
				General = {
					ControllerMode = "bredr";
			pulseaudio.enable = true;
			system76 = {
				enableAll = true;
				kernel-modules.enable = true;
		home-manager = {
			useGlobalPkgs = true;
			users.isaac = { pkgs, ... }: {
				home = {
					file.".git-prompt.sh".source = "${pkgs.git}/share/git/contrib/completion/git-prompt.sh";
					stateVersion = "23.05";
				programs = {
					bash = {
						# urxvt has a bug that starts text 23ish lines in. Remove clear from initExtra when this is fixed.
						initExtra = ''
							source ~/.git-prompt.sh;
							PS1='\n\[\033[1;32m\][\[\e]0;\u@\h: \w\a\]\u:\w\033[35m\]$(__git_ps1 " (%s)")\033[32m\]]\$\[\033[0m\] '
							clear
						shellAliases = {
							dual-monitor = "xrandr --output HDMI-1 --right-of eDP-1 --auto";
							rebuild = "sudo nixos-rebuild switch";
							single-monitor = "xrandr --output HDMI-1 --off";
					git = {
						extraConfig = {
							push.autoSetupRemote = true;
						userEmail = "isaac.shaha64@gmail.com";
						userName = "Isaac Shaha";
					i3status = {
						enableDefault = false;
						general = {
							colors = true;
							interval = 1;
						modules = {
							"battery all" = {
								position = 4;
								settings = {
									format = "%status %percentage ⏳%remaining";
									integer_battery_capacity = true;
									low_threshold = 20;
									status_bat = "🔋";
									status_chr = "🔌";
									threshold_type = "percentage";
							"ethernet _first_" = {
								position = 3;
								settings = {
									format_down = "";
									format_up = "🌐Ethernet: %speed";
							"tztime local" = {
								position = 1;
								settings = {
									format = "📅%A, %B %e, %Y ⌚%l:%M:%S %p";
							"volume master" = {
								position = 5;
								settings = {
									format = "🔊%volume";
									format_muted = "🔇%volume";
							"wireless _first_" = {
								position = 2;
								settings = {
									format_down = "";
									format_up = "🌐%essid: %quality";
					urxvt = {
						extraConfig = {
							background = "black";
							foreground = "white";
						fonts = [
							"xft:Mono:size=10"
						iso14755 = false;
						keybindings = {
							"Shift-Control-C" = "eval:selection_to_clipboard";
							"Shift-Control-V" = "eval:paste_clipboard";
						shading = 20;
						transparent = true;
					vscode = {
						extensions = with pkgs.vscode-extensions; [
							esbenp.prettier-vscode
							github.copilot
							grapecity.gc-excelviewer
							jnoortheen.nix-ide
							ms-vscode-remote.remote-ssh
				services.picom = {
					fade = true;
					fadeSteps = [
						0.1
						0.1
				xsession.windowManager.i3 = {
					config = {
						bars = [
								colors = {
									background = "#000000CB";
								command = "i3bar --transparency";
								fonts = {
									names = [ "Futura" ];
									style = "Bold";
									size = 10.0;
								statusCommand = "i3status";
						defaultWorkspace = "workspace number 1";
						keybindings = lib.mkOptionDefault {
							"XF86AudioRaiseVolume" = "exec --no-startup-id pactl set-sink-volume @DEFAULT_SINK@ +10% && $refresh_i3status";
							"XF86AudioLowerVolume" = "exec --no-startup-id pactl set-sink-volume @DEFAULT_SINK@ -10% && $refresh_i3status";
							"XF86AudioMute" = "exec --no-startup-id pactl set-sink-mute @DEFAULT_SINK@ toggle && $refresh_i3status";
							"XF86MonBrightnessUp" = "exec --no-startup-id light -A 10";
							"XF86MonBrightnessDown" = "exec --no-startup-id light -U 10";
						modes = {
							resize = {
								"${i3-modifier}+r" = "mode default";
								Down = "resize grow height 10 px or 10 ppt";
								Escape = "mode default";
								Left = "resize shrink width 10 px or 10 ppt";
								Return = "mode default";
								Right = "resize grow width 10 px or 10 ppt";
								Up = "resize shrink height 10 px or 10 ppt";
						modifier = i3-modifier;
						startup = [
							{ command = "--no-startup-id light-locker"; }
							{ command = "--no-startup-id lxqt-policykit-agent"; }
						window.commands = [
								command = "move position center";
								criteria = {
									floating = true;
					extraConfig = "floating_maximum_size 1920 x 1080";
		i18n.defaultLocale = "en_CA.UTF-8";
		networking = {
			extraHosts = ''
				127.0.0.1	openparl.cluster-cia2zobysfwo.us-west-2.neptune.amazonaws.com
			hostName = "isaac-nixos";
			networkmanager.enable = true;
		programs = {
			light.enable = true;
			ssh.startAgent = true;
			xss-lock = {
				lockerCommand = "light-locker-command -l";
		security.polkit.enable = true;
		services = {
			blueman.enable = true;
			gnome.gnome-keyring.enable = true;
			xserver = {
				displayManager = {
					defaultSession = "none+i3";
					sessionCommands = "xrandr --output HDMI-1 --right-of eDP-1 --auto";
				dpi = 120;
				layout = "us";
				libinput = {
					touchpad.naturalScrolling = true;
					extraPackages = with pkgs; [
						dmenu
						i3status
		system.stateVersion = "23.05";
		time.timeZone = "America/Vancouver";
		users.users.isaac = {
			description = "Isaac Shaha";
			extraGroups = [ "docker" "networkmanager" "video" "wheel" ];
			isNormalUser = true;
			packages = with pkgs; [];
		virtualisation.docker.enable = true;
I believe the only configurations I have that may relate to this problem are:
  • hardware.pulseaudio.enable = true
  • hardware.system76.enableAll = true
  • hardware.system76.kernel-modules.enable = true
Figured it out with the help of System76 support. Relevant parts of their response:
There is a kernel patch which adds microphone support. I believe it is in the 6.4 kernel so if you add this line to your configuration, rebuild then reboot it should work:
sudo systemctl reboot
Shout out to Aaron @ System76 – great support :slight_smile: .
