Hi
I recently noticed a strange behavior on NixOS, and I would like to understand it and find a workaround.
I have 2 NixOS installed, a desktop (with gnome) and a server (headless, no xserver), I noticed that on my server the /run/current-system/sw/share
is missing a bunch of symlinks. I noticed it because I enabled autojump
plugin to my zsh
config, and on my server, the plugin is not able to load the autojump configuration file. The file /run/current-system/sw/share/autojump/autojump.zsh
exists on my desktop, and doesn’t on my server.
I was able to reproduce this with a virtual machine.
First I install a simple nixos with autojump
package
environment.systemPackages = with pkgs; [ autojump ];
The autojump
symlink is not created. There is not a single symlink created.
ls -l /run/current-system/sw/share
total 112
dr-xr-xr-x 2 root root 4096 1 janv. 1970 appdata
dr-xr-xr-x 2 root root 4096 1 janv. 1970 applications
dr-xr-xr-x 3 root root 4096 1 janv. 1970 bash-completion
dr-xr-xr-x 5 root root 4096 1 janv. 1970 dbus-1
dr-xr-xr-x 2 root root 4096 1 janv. 1970 desktop-directories
dr-xr-xr-x 2 root root 4096 1 janv. 1970 doc
dr-xr-xr-x 2 root root 4096 1 janv. 1970 emacs
dr-xr-xr-x 2 root root 4096 1 janv. 1970 hunspell
dr-xr-xr-x 3 root root 4096 1 janv. 1970 icons
dr-xr-xr-x 2 root root 4096 1 janv. 1970 info
dr-xr-xr-x 2 root root 4096 1 janv. 1970 kservices5
dr-xr-xr-x 2 root root 4096 1 janv. 1970 kservicetypes5
dr-xr-xr-x 2 root root 4096 1 janv. 1970 kxmlgui5
dr-xr-xr-x 19 root root 4096 1 janv. 1970 man
dr-xr-xr-x 2 root root 4096 1 janv. 1970 metainfo
dr-xr-xr-x 15 root root 4096 1 janv. 1970 mime
dr-xr-xr-x 2 root root 4096 1 janv. 1970 nano
dr-xr-xr-x 2 root root 4096 1 janv. 1970 org
dr-xr-xr-x 2 root root 4096 1 janv. 1970 pixmaps
dr-xr-xr-x 4 root root 4096 1 janv. 1970 polkit-1
dr-xr-xr-x 2 root root 4096 1 janv. 1970 sounds
dr-xr-xr-x 2 root root 4096 1 janv. 1970 systemd
dr-xr-xr-x 2 root root 4096 1 janv. 1970 terminfo
dr-xr-xr-x 2 root root 4096 1 janv. 1970 themes
dr-xr-xr-x 2 root root 4096 1 janv. 1970 thumbnailers
dr-xr-xr-x 2 root root 4096 1 janv. 1970 vim-plugins
dr-xr-xr-x 2 root root 4096 1 janv. 1970 vulkan
dr-xr-xr-x 3 root root 4096 1 janv. 1970 zsh
But is I install Gnome desktop with
services.xserver.desktopManager.gnome.enable = true;
I get the autojump symlinks (and many other symlinks) …
lrwxrwxrwx 1 root root 74 1 janv. 1970 autojump -> /nix/store/75vxv4ibjlimcwyhvgl6cv9xa50xm5nj-autojump-22.5.3/share/autojump
I imagine there is a reason for this, but could someone explain it to me?
And is there a way to force the symlinks creation on headless installs?
Thanks
