Missing manpage for nix-env and others
Hi,
I don’t see to have a manpage for nix-env, and other nix commands, such as nix-store and nix-shell:
❯ nix-env --help
No manual entry for nix-env
However, I do have manpages for “nix3” commands:
❯ man -w nix3-repl
/nix/store/iwgkck1d64s5f26ngln540hpf06g28py-nix-2.20.1/share/man/man1/nix3-repl.1.gz
I installed the man-pages and man-db packages, but it doesn’t help.
I’m using Nix as a package manager, with nixpkgs-unstable.
Am I missing some package? If so, which one?
Thanks!
Thanks!
My conclusion: if you want to learn Nix, use the latest nixos channel, and not nixpkgs-unstable, which is really unstable. For other newbies, those are the commands that helped me:
nix-channel --remove nixpkgs
nix-channel --add https://nixos.org/channels/nixos-23.11 nixos
nix-channel --update
nix-env -iA nixos.nix
Thanks, that helped.
Unfortunately, I didn’t find a way to add latest stable release, without setting the version numbers literally:
