I’m running NixOS in WSL and am unable to update (nixos-rebuild switch) after my company changed firewall providers. All my coworkers were able to get around this by following these steps:
- Extract firewall cert
sudo cp firewall.crt /usr/local/share/ca-certificates/sudo update-ca-certificates
It’s my understanding that the equivalent for NixOS would be adding the cert to either security.pki.certificateFiles or security.pki.certificates.
However I’m not able to do this because (seemingly) it’s not possible for me to update my config without a network connection, and I can’t connect to the network without updating my config. I’ve tried a few things to get around the cert issue.
- Set
NIX_SSL_CERT_FILEand addedssl-cert-fileto nix.conf. Had to setNIX_CONFIGto target an writable config file [1][2] - Run
nixos-rebuildwith--option substitute false[3] - Acquire openssl/update-ca-certificates via a nix shell with
NIX_SSL_CERT_FILEset
None of these worked for me. I’m not sure what to try next, any help would be appreciated.
[1] Use a custom TLS/SSL CA in the nixos installer
[2] nix.conf - Nix Reference Manual
[3] Rebuild NixOS Offline - #8 by rnhmjoj
