Mixing stable and unstable packages on flake-based NixOS system
Hello everyone. My system is based on flakes (nix-channel is disabled). How can I use some packages from nixos-unstable while keeping the rest of my system on the stable branch? I’d like to achieve something like this:
    firefox
    thunderbird
    unstable.osu-lazer-bin
In other words, I wanna be able to access osu-lazer-bin from the unstable branch via pkgs.unstable.osu-lazer-bin.
I’ve already seen multiple approaches to achieve this, but none of them worked for me, maybe it’s because my system uses flakes, idk.
translated with llama 3.1 405b :3
You should be able to add the unstable nixpkgs as part of your inputs, then import it and add that package directly. Something like this:
    nixpkgs.url = "github:nixos/nixpkgs/release-24.05";
    nixpkgs-unstable.url = "github:nixos/nixpkgs/nixpkgs-unstable";
 outputs = {nixpkgs, nixpkgs-unstable, ... }:
   system = "x86_64-linux";
   pkgsUnstable = import nixpkgs-unstable { inherit system; };
    # now along with `pkgs` you also have `pkgsUnstable`
    # and can do: pkgsUnstable.osu-lazer-bin
Something like this should work:
  overlay-unstable = final: prev: {
    unstable = import nixpkgs-unstable {
      inherit system;
      config.allowUnfree = true;
    inherit system;
    config = {
      allowUnfree = true;
    overlays = [
      overlay-unstable
Then you can do pkgs.firefox or pkgs.unstable.firefox.
EDIT: Huge caveat - I strongly recommend not mixing stable with unstable on the same system. It’s unsupported and can lead to confusing errors when going to run programs, due to glibc and graphics driver mismatches.
Never set pkgs directly in the NixOS module system, as the other answers are indicating.
Here’s a couple of concepts you need to know:
  1. If you want to access some inputs, or some other value across your config without creating an explicit option for it, use specialArgs or _module.args. (For things that you import, you must pass them in specialArgs specifically to avoid infrec.)
  2. Changing pkgs requires an overlay; however, for this application, you may not necessarily need one if you are willing to get away from the pkgs.unstable syntax specifically.
Which means the following:
  1. Add an entry to your inputs, and pass them to your config via specialArgs, in your flake.nix:
      nixpkgs.url = "github:NixOS/nixpkgs/nixos-24.05";
      nixpkgs-unstable.url = "github:NixOS/nixpkgs/nixos-unstable";
    outputs = { nixpkgs, ... }@inputs:
      nixosConfigurations = {
        foo = nixpkgs.lib.nixosSystem {
          specialArgs = { inherit inputs; };
  2. Since you need an unfree package specifically, allow the unfree package somewhere in your NixOS config:
      nixpkgs.config.allowUnfreePredicate = pkg: builtins.elem (lib.getName pkg) [
        "osu-lazer-bin"
    or if you want, you can just blanket allow all unfree packages, that’s up to you:
  3. Then, use that config when importing the unstable nixpkgs, and then use the appropriate module arg in your package list.
    a. EITHER create a new module arg:
    { config, inputs, pkgs, pkgsUnstable, ... }:
      # this allows you to access `pkgsUnstable` anywhere in your config
      _module.args.pkgsUnstable = import inputs.nixpkgs-unstable {
        inherit (pkgs.stdenv.hostPlatform) system;
        inherit (config.nixpkgs) config;
    b. OR, add an overlay to modify the existing nixpkgs instance (pkgs):
    { inputs, pkgs, ... }:
      nixpkgs.overlays = [
        (final: _: {
          # this allows you to access `pkgs.unstable` anywhere in your config
          unstable = import inputs.nixpkgs-unstable {
            inherit (final.stdenv.hostPlatform) system;
            inherit (final) config;
I’m personally against 3b, because an overlay for this is completely unnecessary and will likely slow down eval.
PS this has got to be one of the most-asked questions, it’s silly that we are still having to rewrite the answers from scratch in 2024…
Is that what is happening here?
You could add an article to nix.dev or the wiki.
Perfect! Used option 3a, this should definitely be written somewhere in the docs, at least not official.
Hello, I am a bit new to flakes and the nix syntax. The tutorial i followed led me to a different outputs syntax so i am not sure how i can follow your step 1. Can you help? I am figuring this stuff out as i go so there are some holes in my understanding.
  description = "My system configuration";
  outputs = { self, nixpkgs, ... }:
      lib = nixpkgs.lib;
        tartarus = lib.nixosSystem {
          modules = [ ./configuration.nix ];
          # revision = self.shortRev or self.dirtyShortRev or self.lastModified or "unknown";
Hey! Since you are new, I’ll throw in some syntax explanation. If you open your configuration.nix, you’ll see something like this:
{ config, pkgs, ... }:
  imports = [ ./hardware-configuration.nix ];
This is a nix function. On the first line you can see the attribute set that would be used as an argument, and the big attribute set after : is the return of the function.
So when you rebuild your system with a flake that you provided, here
you call a function lib.nixosSystem that creates a configuration tartarus for you. Somewhere inside that lib.nixosSystem function the following happens:
  • config is extracted from nixpkgs
  • pkgs is extracted from nixpkgs. It looks something like pkgs = nixpkgs.legacyPackages.${system}; (system is provided by you in argument to nixosSystem)
  • ./configuration.nix is read and called with these (and other) arguments
What you need to do is to extract the unstable version of pkgs and provide it in inputs to function in ./configuration.nix.
To do this nixosSystem allows you adding attributes that would be used in calls to functions from modules. You can add attribute specialArgs = { /* your args */ }; and your args would be used in a call to function in ./configuration.nix. And you would also need to modify ./configuration.nix by adding unstable version of pkgs as input.
So you’ll get something like this:
# In your flake declaration
  lib = nixpkgs.lib;
  pkgs-unstable = unstable.legacyPackages.${system};
      inherit system; # inherited it from 'let' block
      specialArgs = { inherit pkgs-unstable; };
# In your configuration.nix:
{ config, pkgs, pkgs-unstable, ... }:
    neovim # package from pkgs
    pkgs-unstable.ripgrep # package from pkgs-unstable
Wow, thank you so much for the detailed explanation. This is literally a game changer. One can write a very dynamic configuration logic with this. It is awesome.
Hey,
should be
pkgs-unstable = inputs.unstable.legacyPackages.${system};
Yes. Feel free to try and report feedback.
I tested it and the following error will show:
error: undefined variable 'unstable'
So the fixed code will look like this:
outputs = { self, nixpkgs, ... }@inputs:
  lib = nixpkgs.lib;
{ config, pkgs, unstable, ... }:
Also I don’t know if the following line is the correct way of adding additional arguments to nixos modules:
I have multiple inputs in my flake.nix so I have declared this as:
nixosConfigurations.pc = nixpkgs.lib.nixosSystem rec {
   specialArgs = inputs // { unstable = inputs.unstable.legacyPackages.${system}; };
Run nix flake update !
hello, having the same issue, but want to use unstable inside home-manager.
my flake.nix:
    nixpkgs.url = "github:NixOS/nixpkgs/nixos-24.11";
    home-manager = {
      url = "github:nix-community/home-manager/release-24.11";
  outputs = {self, nixpkgs, nixpkgs-unstable, home-manager, ...}@inputs: {
    nixosConfiguration.cesium = nixpkgs.lib.nixosSystem {
      modules = [
        ./configuration.nix
        home-manager.nixosModules.home-manager {
          ./home.nix
my home.nix:
{inputs, config, pkgsUnstable, pkgs, ...}: {
  programs.wezterm = {
    package = pkgsUnstable.wezterm;
but i am getting this error message:
error:
         at /nix/store/h3g3hcnwm00lhr41fj9d9ahy002d6h7k-source/lib/attrsets.nix:1574:11:
         1573|         || pred here (elemAt values 1) (head values) then
         1574|           head values
         1575|         else
         at /nix/store/h3g3hcnwm00lhr41fj9d9ahy002d6h7k-source/lib/modules.nix:816:9:
          815|     in warnDeprecation opt //
          816|       { value = addErrorContext "while evaluating the option `${showOption loc}':" value;
          817|         inherit (res.defsFinal') highestPrio;
       error: attribute 'inputs' missing
       at /nix/store/h3g3hcnwm00lhr41fj9d9ahy002d6h7k-source/lib/modules.nix:515:48:
          514|         addErrorContext (context name)
          515|           (args.${name} or config._module.args.${name})
          516|       ) (functionArgs f);
you also need the counterpart for HM: home-manager.extraSpecialArgs (in modules or so on).
solved it, many thanks.
I’m getting
       error: attribute 'pkgsUnstable' missing
       at /nix/store/s3bhg6p26cqi1hm2lamjjdwaiq49g2hn-source/lib/modules.nix:515:28:
I also don’t understand how we get a variable pkgsUnstable just by adding an input nixpkgs-unstable in our flake. Similarly, I don’t understand how we get an input pkgs for our modules by adding a nixpkgs input to our flake.
you might be missing these.
Do not do what @aos suggested because your nixpkgs config (e.g. setting unfree) will not carry over.
Please reread my post in full and perform every step. I explained exactly how to pass in nixpkgs-unstable flake input into the module system (step 1) and add a module arg pkgsUnstable (step 3a).
pkgs specifically is a bit of behind-the-scenes-magic. It comes from whichever nixpkgs input you use to call lib.nixosSystem.
But pkgsUnstable you have to create manually, which was the entire point of my reply.
I have now settled with the following config, mixing stable and unstable packages and a testing host going fully unstable:
#flake.nix
  description = "Nixos config flake";
    nixpkgs.url = "github:nixos/nixpkgs/nixos-24.11";
    nixpkgs-unstable.url = "github:nixos/nixpkgs/nixos-unstable";
  outputs = { self, nixpkgs, nixpkgs-unstable, ... }@inputs:
      lib = nixpkgs.lib;
      variables = nixpkgs.lib.importJSON ./secrets/variables.json;
        inherit system;
      specialArgs = {
        inherit inputs;
        pkgs-unstable = pkgsUnstable;
      nixosConfig = { configPath, useUnstable ? false }:
          nixpkgsSrc = if useUnstable then nixpkgs-unstable else nixpkgs;
        nixpkgsSrc.lib.nixosSystem {
          modules = [ configPath ];
        prodhost= nixosConfig { configPath = ./hosts/prodhost/configuration.nix; };
        testhost = nixosConfig { configPath = ./hosts/testhost/configuration.nix; useUnstable = true; };
Declaring packages
  environment.systemPackages = (with pkgs; [
    stable-package
  (with pkgs-unstable; [
     unstable-package
