Hello, I have two monitors, one 1440p and one 1080p, I would like to, on boot, boot into a tty with true color support unlike the normal tty. Then it should run a command ‘foo’ (not putting the real command for security reasons) in that colored tty. BUT, the 1440p monitor should mirror the 1080p one until I start hyprland manually, when monitor configs are transfered to it.
System Info:
Nvidia GPU
my nixOS config: Z then # could be conflicts between.
