Plofkat
September 21, 2023, 6:39am
1
Hi, I’m very new to nixos and at the moment I’m testing a lot of thigs I usually use at work.
Usually I would connect to my moosefs share with the following line in my /etc/fstab
mfsmount /mnt/mfs fuse mfsmaster=mfs-master01,_netdev 0 0
How does this translate to the configuration.nix file?
You just need to enable the client side utilities and add entry to fileSystems`:
services.moosefs.client.enable = true;
fileSystems = {
"/mnt/mfs" = {
fsType = "moosefs";
device = "mfs-master01:/";
options = [ "_netdev" ];
Plofkat
September 22, 2023, 5:28am
3
Worked first try, thank you. I expected it to be a bit more complicated to be honest.
Is there any documentation I can reference for stuff like setting up master, metalogger and chunk servers?
All the options are listed here:
https://search.nixos.org/options?channel=unstable&from=0&size=50&sort=relevance&type=packages&query=moosefs
The services.moosefs.*.settings
parameters takes the config file options for the config files. I.e.,this example configures chunk server and a metalogger:
services.moosefs = {
masterHost = "mfsmaster";
metalogger = {
settings.DATA_PATH = "/srv/moosefs/meta/logger";
chunkserver = {
hdds = [ "~/srv/moosefs/data" ];
settings = {
DATA_PATH = "/srv/moosefs/meta/chuncks";
LABELS = "A";
Plofkat
September 22, 2023, 12:42pm
5
Thanks, this is very helpful.
