Mullvad in nixos container keeps in the "connected and connecting" loop
It keeps “connected and connecting” very frequently like 30-60 seconds for a cycle.
It is connected for a very short time (a few second) and then it become “connecting” and find another node to connect.
And then it is connected for only a few second and then find an new node to connect again.
It repeats again and again.
I disabled quantum resistance, disabled multihop, using wireguard, only turned on lock down mode
Still no luck
# https://headless-render-api.com/blog/2024/04/08/mullvad-vpn-containerized-nixos
{ lib, ... }:
  containerName = "mullvad";
  externalInterface = "eth0";
  # https://blog.beardhatcode.be/2020/12/Declarative-Nixos-Containers.html
  networking.nat = {
    internalInterfaces = [ "ve-${containerName}" ];
    inherit externalInterface;
  # https://github.com/mullvad/mullvadvpn-app/issues/5408#issuecomment-1805189128
  fileSystems."/tmp/net_cls" = {
    device = "net_cls";
    fsType = "cgroup";
    options = [ "net_cls" ];
  containers.${containerName} = {
    autoStart = true;
    privateNetwork = true;
    hostAddress = "192.168.100.10";
    localAddress = "192.168.100.11";
    bindMounts = {
      "/etc/mullvad-vpn" = {
        hostPath = "/persist/etc/mullvad-vpn";
        isReadOnly = false;
      "/var/cache/mullvad-vpn" = {
        hostPath = "/persist/var/cache/mullvad-vpn";
        isReadOnly = false;
      "/var/log/mullvad-vpn" = {
        hostPath = "/persist/var/log/mullvad-vpn";
        isReadOnly = false;
    config =
      { pkgs, ... }:
        system.stateVersion = "25.05";
        services.mullvad-vpn.enable = true;
        networking = {
          firewall.allowedTCPPorts = [ 80 ];
          firewall.enable = false;
          hostName = containerName;
          useHostResolvConf = lib.mkForce false;
        services.httpd = {
          adminAddr = "admin@example.org";
        # Reported some Mullvad-vpn doesn't work correctly with systemd-resolved
        # https://github.com/mullvad/mullvadvpn-app/issues/6063
        # But nixos wiki recommended this
        # https://wiki.nixos.org/wiki/NixOS_Containers
        services.resolved.enable = true;
The trick is just manually typing mullvad disconnect and mullvad connect, to dirty bypass the reconnect bug.
It was mentioned in the link:
3. add mullvad disconnect/connect inside container to fix transient reconnect issues
by this:
        # disconnect/reconnect is dirty hack to fix mullvad-daemon not reconnecting after a suspend
        ${pkgs.mullvad}/bin/mullvad disconnect
        sleep 0.1
        ${pkgs.mullvad}/bin/mullvad connect
