I have a HP Pavilion 15-eg3xxx, with realtek ALC287, RTL8852BE, the mute button is on the F5 key. The key is working but the led doesn’t work. There are numerous posts on the Arch Forums and the Arch Wiki talks a bit about this, too. But I was wondering if there are patches/workarounds specific to NixOS. The kernel version is linux-6.10.6 and I have a flake enabled NixOS 24.11.20240824.d0e1602 (Vicuna x86_64), initial install was 24.05 Uakari x86_64. I use
Well, that’s the problem. I can’t figure it out because my laptop’s config is not there. There have been cases with “lower number” versions of the same laptop I am using where they did seem to fix the problem. But nothing for the likes of hardware I am using. Is there a way to get this into the kernel itself?
I had the same problem on my Thinkpad E14 and had to do it on my own. I configure it via my hyprland keybinds module in home-manager. It should work, but if it doesn’t, try looking up kernel modules for HP to find the right commands.
