My direnv flake.nix is overriding my home.nix shell settings somehow
My home.nix has a programs.zsh section that looks like this:
  programs.zsh = {
    autocd = true;
    enableAutosuggestions = true;
    enableCompletion = true;
    shellAliases = {
      ls = "ls -alG";
      vim = "nvim";
      htop = "btop";
      tmux = "zellij";
    initExtra = ''
      PS1='%(?.%F{green}>.%F{red}?%?)%f %B%F{100}%~%f%b %# ';
      CLICOLOR=1;
      PATH=/Users/mmai/scripts:$PATH;
      NIXPKGS_ALLOW_UNFREE=1;
      setopt rmstarsilent;
This gives me highlighted directory colours when doing “ls”. But when I run the flake below via direnv use flake the directory highlighting is gone in my console:
  description = "R development environment";
  # Flake inputs
    nixpkgs.url = "github:NixOS/nixpkgs"; # also valid: "nixpkgs"
  # Flake outputs
  outputs = { self, nixpkgs }:
      # Systems supported
      allSystems = [
        "x86_64-linux" # 64-bit Intel/AMD Linux
        "aarch64-linux" # 64-bit ARM Linux
        "x86_64-darwin" # 64-bit Intel macOS
        "aarch64-darwin" # 64-bit ARM macOS
      # Helper to provide system-specific attributes
      forAllSystems = f: nixpkgs.lib.genAttrs allSystems (system: f {
      # Development environment output
      devShells = forAllSystems ({ pkgs }: {
        default = pkgs.mkShell {
          # The Nix packages provided in the environment
          packages = with pkgs; [
            R
            rPackages.xts
            rPackages.glmnet
            rPackages.ggplot2
            rPackages.reshape2
            rPackages.lattice
            rPackages.quantreg
            rPackages.gridBase
            radianWrapper
            rPackages.ggplot2
            rPackages.xts
            rPackages.ggsci
            rPackages.ragg
            rPackages.viridis
            rPackages.forcats
            rPackages.ggridges
            rPackages.scales
            rPackages.RColorBrewer
            rPackages.cowplot
            rPackages.magick
            rPackages.RPostgreSQL
            rPackages.DBI
            rPackages.devtools
            rPackages.tidyverse
Shouldn’t it be inheriting my home.nix environment automatically? Or do I need to add something to this flake?
I had an issue with the same symptoms and came across this post, so here is my solution.
The problem is not that the environment is not inherited, indeed:
~ $ echo $CLICOLOR
1
~ $ cd dev/ffmpeg
direnv: loading ~/Dev/ffmpeg/.envrc
~/dev/ffmpeg $ echo $CLICOLOR
1
Rather the issue is that entering the dev shell changes which ls executable is in use, from one supplied by the system to one supplied by Nix:
~ $ which ls
/bin/ls
~ $ cd dev/ffmpeg
~/dev/ffmpeg $ which ls
/nix/store/27hlrqpjy40ifmmy3rw2fbi5b57l8cmw-coreutils-9.5/bin/ls
The version of ls supplied by Nix had slightly different semantics to the one supplied by the system in my case. Specifically, the version supplied by Nix requires the --color=auto flag in order to print colourful output. I fixed the issue, then, by aliasing ls to ls --color=auto.
