My nixos-rebuild switch doesnt work
when i try to run sudo nixos-rebuild switch it gives me this error
building Nix…
building the system configuration…
Assertion ‘n <= st.st_size + 1’ failed at src/basic/efivars.c:110, function efi_get_variable(). Aborting.
File “/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot”, line 431, in
main()
File “/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot”, line 414, in main
install_bootloader(args)
File “/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot”, line 317, in install_bootloader
installed_out = run(
File “/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot”, line 58, in run
return subprocess.run(cmd, check=True, text=True, stdout=stdout)
File “/nix/store/jd20rkmqmkfkcvk2wl2lmzz7acq4svlr-python3-3.12.12/lib/python3.12/subprocess.py”, line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘[’/nix/store/2dqf465jfs9w73jihy4yk8yc47673i18-systemd-257.10/bin/bootctl’, ‘–esp-path=/boot’, ‘status’]’ died with <Signals.SIGABRT: 6>.
Failed to install bootloader
I second this. Since today I’m getting a very similar error when rebuilding, even though I didn’t change anything besides new fonts (which I reverted but still get the error)
 sudo nixos-rebuild switch --flake .#nixos
Assertion 'n <= st.st_size + 1' failed at src/basic/efivars.c:110, function efi_get_variable(). Aborting.
  File "/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot", line 431, in <module>
    main()
  File "/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot", line 414, in main
  File "/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot", line 317, in install_bootloader
  File "/nix/store/zlb2i0qml2rmaqc7qdpgkhak0m7fv336-systemd-boot/bin/systemd-boot", line 58, in run
  File "/nix/store/jd20rkmqmkfkcvk2wl2lmzz7acq4svlr-python3-3.12.12/lib/python3.12/subprocess.py", line 571, in run
subprocess.CalledProcessError: Command '['/nix/store/2dqf465jfs9w73jihy4yk8yc47673i18-systemd-257.10/bin/bootctl', '--esp-path=/boot', 'status']' died with <Signals.SIGABRT: 6>.
It looks like the assertion it’s failing on was added in the latest systemd version bump (about 3 weeks ago):
It also looks like I can only reproduce this after resuming from hibernation. I don’t run into this problem after rebooting (until my system goes into hibernation again).
Bug fix is here, but it’s unclear whether it’ll land in 25.05 which goes end-of-life very soon
@nito and @yurix73 can you confirm if rebooting before trying nixos-rebuild again works around this issue?
Hi, for me it works now after rebooting. Thank you!
ok so i did some testing and the issue only happens if you return from hibernation and try to sudo nixos-rebuild switch --upgrade after you run that command sudo nixos-rebuild swtich will be broken for the whole hibernation session
same symtoms on my end only happens after resuming from hibernation
Same thing for me, also using hibernation
it sound to be the same as in nixos/systemd-boot: Failed to install bootloader if /boot/loader/random-seed does not exist · Issue #461676 · NixOS/nixpkgs · GitHub
